Sonodyne SM100AK MOD
Hello everybody,
I have these, SM100AK speakers, bought quite a few years ago. They are nice, but I think there are things to improve.
So from time to time, I make some mods, so to make them sound as much as they can. Worth it or not, to put money in these, not sure, but it is like a sport
and it is kind of interesting how things can evolve and improve 🙂
So what was done. I have changed all electrolytic caps to Panasonic FC and Panasonic NHG 4800uF in the power supply. There are some left few Chinese bipolars and
I'm thinking to change them to 'Muse'..? The film caps are Polyphenylene Sulfide, I don't why I changed not to Polypropylene, but it was done a long time ago. Is there much difference between Polyprops and these? Would you increase the size of the power caps? Bypass them with film caps? What would do to improve it?
I have shorted the Volume pots, and improved the sound a lot. The box is made of aluminum, so it has a very nice metallic sound 🙂 I have put bitumen adhesive material inside the walls and that was an improvement as well.
I'm wondering to change the ICs now. It has 3 x TL074 and 1 x NE554. 3 x opa1644 + 1 x opa1612? What do You think?
Any ideas are very welcome on how to improve it even more?
Thanks and have a good day.
22uF on Power pins?
Why not change? It would need some changes around ICs? Would do more mess than good? Not even 5534?
I don't remember the exact effect when the caps were changed, but shorted potentiometer improved clarity a lot. And some weird weirdness between speakers disappeared, some phase thing in some frequencies. Removed box resonances with bitumen improved clarity, and separation as well.
22uF on Power pins?
I experienced more powerful sound in presence and authority putting a small electrolytic directly between the plus minus pin of every op Amp. You can easily check this out with A /B comparison with a Mono signal between the two speakers.
Bitumen on the inner walls is certainly a good tweak for better sound
Wonderful info, I will try 22uF mod. thanks. It uses TDA7296 chip amps.
Yes, I'm aware of oscillation. Is there maybe some 'safe bet', to avoid oscillation, without measuring?
AND there is a ceramic cap in the HF+ path, labeled PSW. What it is for? Kind of buffer not to blow the HF driver when powering the speakers?
Ceramic cap - how many microfarads has it? Is it in parallel with another cap?
Good next tweak: avoid lose wadding in a reflex box. Take it out and put on all sides if possible pyramid foam so that it does not move or vibrate. You get better transients in the bass.
Put a piece of foam glued to the backside of the bass magnet (omit closing vented pole piece) the foam is in the middle of the box and reduces resonances which cannot be reached by foam on the sides on the enclosure
I am not an expert for op amps but if you take the TL074 out and put one in which is not "faster" it could work. Which other one I have no suggestion. But usually you have to check if they are in the signal path. If not do not touch them.
The ceramic cap has this marking '12 XF 040' - 0,12uF 40V?
It is in series, in HF+ signal path. I'm not sure at the moment, but I think the signal goes from the inductor to this ceramic cap to HF+ output.
"Good next tweak: avoid lose wadding in a reflex box. Take it out and put on all sides if possible pyramid foam so that it does not move or vibrate. You get better transients in the bass.
Put a piece of foam glued to the backside of the bass magnet (omit closing vented pole piece) the foam is in the middle of the box and reduces resonances which cannot be reached by foam on the sides on the enclosure"
VERY INTERESTING, thanks!
It seems the ceramic cap is a small one. I only saw a small ceramic cap in a Acoustic Research HiRes Loudspeaker AR15 in parallel to MKT capacitors. However changing the one MKT capacitor which was in series before the tweeter with a polypropylene type was clearly audible better in sound.
Is the loudspeaker a two way active system? Then a capacitor in series before the tweeter is not plausible. Has it a two way crossover? And the amplifier is mono in the loudspeaker? Just one amp for a classicla two way loudspeaker with passive crossover?
TL74 and Tl072 have a sonic signature. They can sound nice and pleasant. If you like thw sound now do not change them. If not try NE5543/32 this is a good op amp cncerning noise. or 4558. last one is sonically neutral. most i like lm4562.
No love for Burrbrown opamps? 🙂 My aim is for as much neutrality as possible.
Would be safe to bypass the ceramic cap for HF+ output?
There are two bipolar electrolytic at the signal input. + and - have each 10uF bipolar. Any ideas about what they are there for?
You can change the 10 mfd electrolytic for 10 mfd wima 50v. OP amps - everyone has its taste.
I can not believe that the ceramic cap is in front of the tweeter it makes no sense in an active speaker. I would not touch it.
Thank you all for this thread. I've been on SM100AK as my daily drivers for about 12 years now and reading this made me realize that I have done exactly zero maintenance on them this whole time.
Just working out the master volume with deoxit really cleared things up, pots were pretty scratchy so I doubt there was a 100% good connection at the wiper. I also cleaned the internal molex connectors and the other trim pots. I'd love to short the volume knob out of the circuit, but I run at about 50% volume to match my space and my subwoofer. Could maybe replace the pots with a matched pair of fixed-value resistors. (Also maybe put a resistor in the power LED circuit -- I taped over the LEDs years ago because they are too bright and pointed right at me, very distracting. I'd love it if they were on but just much dimmer.)
I was surprised to find the one piece of sonic treatment just floating around inside the cabinet. I applied foam to the inner walls of the cabinet, as well as the back of the LF driver magnet. This made a pretty big change. Before this change I had a tiny and well-defined sweet spot and I really needed to have my head in the right position to experience it. Now I do not notice a distinct boundary to the sweet spot. Pretty great!
I am also curious about the op amp / filter cap mod. Has anyone done this & willing to share pics / results?
I build loudspeakers very often. End users who only buy ready made boxes often try to influence the sound with cables and so on.
But as a designer I know how much the mechanics is crucial for the sound as I try a lot of changes and listen to them: correct damping in the box, damping resonances of the box walls, getting rid of diaphragm resonances all this makes big differences in sound - magnitudes higher than cable issues.
