Hello All,
Im looking for suggestions for some nice tops to cover HF (400hz up). Looking for something nice and smooth and also to produce high SPL. Will be replacing some A.S.S. mt502s which are a bit harsh and also are a but lacking post 10k (prob to do with their age).
So fair considering Funktion 1 res2sh or mounting some HF solutions in a box (Orbit 4 (top section only)/line array waveguide with BMS 4594HE or similar).
Open to off the shelf and DIY solutions. Not looking for anything with a mid driver as already have 90-600hz covered.
Thanks in advance!
G
Thanks in advance!
G
Orbit 4 top section would be cost effective, in the orbit 4 they are crossed at 400Hz, they are aprox 40 degree conical. What coverage angle do you need?
Not sure about what frequency range you are talking about. Title says "4kHz up" but your post says 400Hz up. Which is it?
Oh sorry! I made a mistake there, its ment to say 400hz. Ive asked the moderator to change it.Not sure about what frequency range you are talking about. Title says "4kHz up" but your post says 400Hz up. Which is it?
B
