I'm getting ready to build a new workbench for the winter silly season of building madness and am in the process of digging out all of my test gear etc.. One item I restored and calibrated a few years ago is a really nice Tektronix 575 curve tracer, but it's approximately the size of a house and I would have to make a rather large space to accommodate it. I know we can static match Idss and such with a simple DVM and test jig, just wondering if a curve tracer would be of benefit for matching JFETS, MOSFETS and SITs (if I ever find any) .
Thanks all,
Cheers
Thanks all,
Cheers
Dude, that is so cool you should make room whether you use it or not. Turn it on have a cup of tea and get to work, sounds awesome.
Unfortunately I would have to run it with the covers on so as to keep my cat alive, the glowing cool factor would be lost. Maybe the cat would like to live outside this winter. 😱
Between the test gear and FW amps running, I would probably not need to light the wood stove.
Cheers
metal mash can be a good solutions , too nice lookingUnfortunately I would have to run it with the covers on so as to keep my cat alive, the glowing cool factor would be lost. Maybe the cat would like to live outside this winter. 😱
Cheers
Seriously, we curve-tracer-match all our devices to <<1% for all our projects,
This gives you the best chance of distortion cancellation in balanced / push-pull circuitry.
But this can only be done if you have a large pool of devices to match from.
AND your equipment is more much accurate than 0.5% and allows you to download the measurement data.
Probably not possible with your Tektronics ?
Patrick
Patrick
Semi off topic: Any tips of how to store a large number (>~ 100) of small SMD critters in numbered way after sorting.
I don't recall seeing a USB port on the old Tek 🤣 and I have no idea what the accuracy is. I think the only way to download data from it would be to take a picture of the scope screen. 🙂
Well, it sounds like it is something I should have available, maybe not in prime real estate, but in the room available when needed.
Cheers
a curve tracer was something I mused about during lockdown...
I got the barebones off the ground using an arduino feeding a windows program. The initial thoughts are here:
https://www.audio-talk.co.uk/phpBB2/viewtopic.php?t=7933
I didn't get very much feedback or encouragement so it languished
No, you can not use a Tektronix 575 or 576 to match MOSFETs. You will exceed their "safe operating area". Tek made a specific plug-in for MOSFET testing with the 576.
If you measure Vgs(th) for devices, at the same temperature, you will get good matches. NP describes the procedure quite well.
Is this unit still available?
That was just a photo for the website, not the equipment we use.
This is what we have been ussing the last years :
https://www.diyaudio.com/community/threads/f5-power-amplifier.121228/post-4795279
Patrick
Patrick
I looked into this and couldn’t find a solution that could do both tubes and SS and especially that intermediate region of 50V-150V at >1A of current. The uTracer6 gets close.
My solution is Mike’s Frankentracer. With the ubiquitous Rigol DS1054Z, you can get this type of output, which is fine for what I need but may not be enough for you:
Any chance that image is for K2087?I looked into this and couldn’t find a solution that could do both tubes and SS and especially that intermediate region of 50V-150V at >1A of current. The uTracer6 gets close.
That is a Schaded (1k-47k) IXTH6N50D2. Looks like a VFET, doesn't it?
Just have to Google it:
https://blog.audiomaker.tech/download/frankentracer-schematic/
Also check out the youtube videos.
- Is a curve tracer beneficial for devices in the FW/PASS amps we build?
