Tripath TA0103A repair attempt
Hello guys
I have had over 5 amps lately for a repair based on the Tripath TA0103A chip, Impulse SD-1200, Phoenix Gold Tantrum 1200.1, Phase Linear Opus 1, US Amps and etc.
Same board same stuff, pictures in the link:
https://amp-performance.de/en/1222-Phase-Linear-Opus-1.html
All of them with a defective output section, some had output mosfets blow up, others only the chip was defective.
I've tried to order TA0103A from 2 different sources from China the chip, but sadly no avail, they were either fakes or blown up
Decided to open up one of the chip....i've found a few blown up transistors. Will try to read the markings and replace them. I know if the ics, big black blobs, are gone it's game over.
But as I have 5 of them just laying around with no other options, i don't have much to loose.
The only issue is that i don't know the values of the capacitors... I highly doubt there is a schematic for the Tripath TA0103A. I've read all of the threads over here about Tripath TA0103A.
Has anyone ever tried to repair one of those ? Any advice ?
Shipping is going to be a killer....Can the FET drivers be replaced ? If I carefully clean up the epoxy, are the drivers an ic or a regular mosfet which can be bought (not something only tripath made) ?
Any advice how to check if the FET drivers are surely blown (which pin to which for short)
Sorry, didn't see your location.
Measure from pins 20-21, 22-21, 25-26, and 27-26. They should all measure in the 3-7MΩ range. If one measures open-circuit or a significantly lower value, then it's dead.
I think the drivers are a Tripath part, but I can't say for certain. The epoxy is pretty much impossible to remove without damaging the board.
So far no luck...i've measured 4 chips...all of them show pretty the same.
20-21 -open
22-21 -10+MΩ
25-26 -10+MΩ
27-26-open
So sad i have to scrap 4 perfectly working amps except the TA0103A IC... I so much dislike all of the electronic waste we are making these days...
