DIY Friendly Low Noise, Low Cost Power Suppy 5...15V 400mA
Triggered by this thread : https://www.diyaudio.com/community/threads/compact-diy-friendly-dual-tps7a3301-power-supply.290858/ .
And the high prices and availability of low noise regulators. And problems with handeling smd parts.
I designed a realy quiet power supply with first a capacitor multiplier and then a TPS7A3301 regulator in TO220-7 housing(Cheap and throuhole).
Totalcost with transfomer,PCB and all parts about 20 euro.
I use two of them for dual rail suppy +/- 15V.
Schematic
R1,Q1,C11 are part of the capacitor multiplier. With 200mA load the ripple before the TPS7A33 is only 5mV. With only 3300uf capactor it was 265mV.
After the TPS7A33 noise/ripple is lower then -120db, this is the limit of my measure equipment.
Transfomer
TPS7A3301 TO220-7 housing.
Got the part for free, from the TI sample program.
PCB
PCB size is 50 x 100 mm. Ordered at JLCPCB for 8 euro(5 pcs).
Gerber files for ordering see below.
Ronny
Reactions: justinhd
That does change things... I assumed you were making a bench power supply. In this case, you could save some money and go with a standard LM317 circuit (or LM337 if you are still wanting to regulate vie the negative rail) - the higher current limit might help with peak demands and will work fine for anything you are powering with it (given the 400mA limit given.)
Hal
For something like that the probable culprit is a ground loop or radiated noise aliasing into the circuit. Quick test is to take a large piece of aluminum foil and cover various parts of the circuit and see if it has any effect. It won't be thick enough to to block low frequency or magnetic interferance, but it can help eliminate some RF issues. A huge source of radiated noise is LED or fluorescent lighting so see if turning the lights out helps. Also an AP close by can cause problems. But still, I would think that the most likely problem is with a ground or a problem with your existing power supply. What you had originally planned was a good idea - it just did nor require that high a performance part.
Hal
Today, the PCB’s came.
Build one and tested ripple below 0.1mV.
Somebody has to do it:
- Distance between diode bridge, transformer and filter caps is small. Please measure temperatures at specified maximum load.
- Through hole may seem to be a design feature but it does not make things easier in a dominantly SMD world.
- Clearance between metallized mounting holes and 230V mains voltage carrying PCB track at the fuse holder is absolutely below required clearance. Please change to normal clearance. Many will use metal standoffs as standard with PSU boards and onboard transformer.
Not wanting to be overly criticizing but please note that you publish stuff on a public DIY website with people copying stuff or having PCBs made. It should be 100% safe. Only add gimmicks and publish when stuff has been reviewed and tested by another person.
