Hey fellow DIYers!
I'm having an issue with the motor unit I'm building for my all-DIY-turntable.
Currently I use a mason DCX 22 motor in an external motor unit built of alloy. The motor itself runs w/o vibrations - but it is quite noisy. I can still hear it from about 2m of distance.
So my question is: What measures can I take to reduce the noise of the motor in the motor unit? Do you know of any materials that I could use to reduce the noise?
Ideas would be gladly appreciated
Stephan
Stephan
Same noise loaded and unloaded? In and outside whatever mounting you're using? I had a rummage and couldn't see any definite specifications though I did see a generic 35dba for the dcx10s. Perhaps contact Maxon and asking them noise levels you might expect, it might be you've got a faulty unit...
Something you can hear from 2m away doesn't sound ideal 🙁 Recording possible? If you can, Maxon might be able to advise based on the noise...
Some years back I purchased a used Heybrook TT2 with a motor that made quite a loud noise and the prior owner had tried all sorts of things to mask it. I stripped them out and took a closer look. Turned out it was not the motor, but a capacitor on the PSU (below the motor) that was buzzing, so I replaced it. Silence.
How long have you had the unit, it should be noise free. If a resent purchase, send it back.
Cheers
Cheers
Hi Stephan,Currently I use a mason DCX 22 motor in an external motor unit built of alloy.
What "alloy" did you use? Brass, bronze, 4130 steel?
Ralf
Same noise loaded and unloaded.
I've now isolated the motor from the motor unit a bit by applying some rubber between the motor housing and the unit which dropped the noise level.
Your "Turned out it was not the motor" made me wonder. So I was looking out for other reasons.
What really made a difference was changing the way the motor unit was coupled to the plate the turntable is standing on. I've now changed it to soft rubber rings I had lying around. And guess what: It's dead silent now!!
So I'll take it from there now and see how I can improve that.
Actually I used a quite soft composition. Still looking for a material I can use inside the motor unit to get it even quieter now.Hi Stephan,
Ralf
The noise can come from the commutator if the DC motor, bearings, or rotor is not balanced properly.
I had one DCX22 (metal brushes CLL ball bearings) too, they are inherently noisy.
Mounting it with rubber is a good idea. I couldn't’ find any picture of it but you might look up how it is done in the Well Tempered Record Player.
Try these I have found them to be great and sized perfect for the 22mm diameter.
https://www.ebay.co.uk/itm/33314965...RllHP1XtHq8ZFxNyFYME4njZA=|tkp:Bk9SR8ad3JzrYA
Motors using ball bearings are almost always more noisier than motors with sinter bronze bearings !
I'm curious as to why you selected that particular alloy of steel. Making a motor pod is mostly about adding mass to dampen the motor. Add a little rubber as needed, etc. I'd venture a guess if it's sufficiently heavy and well damped the material type wouldn't matter except for looks.Hi Stephan,
Ralf
BillWojo
My pod is a bit oversized, so there are a couple of cm each side of the motor body. Made a cardboard cylinder that fits snugly along the motor and filled the empty space inside the pod with a mix of expanding foam and lead granules. It is now almost impossible to hear any noise.
I was just curious as to what particular metal alloy he used. I mentioned some common alloys for no particular reason. I forgot to include the vast number of aluminum alloys though.I'm curious as to why you selected that particular alloy of steel. Making a motor pod is mostly about adding mass to dampen the motor. Add a little rubber as needed, etc. I'd venture a guess if it's sufficiently heavy and well damped the material type wouldn't matter except for looks.
BillWojo
Ralf
Ralf, I can't exactly tell which alloy it actually is. Do you see any differences/ advantages/ disadvantages of specific alloys?I was just curious as to what particular metal alloy he used. I mentioned some common alloys for no particular reason. I forgot to include the vast number of aluminum alloys though.
Ralf
You have received a metal resonator jar. Use sound absorbing materials. Similar ones are used in cars. These are mastics, rugs.Do you see any differences/ advantages/ disadvantages of specific alloys?
- Analogue Source
- motor unit noise
