6SJ7 Distortion Level
I have been playing with the 6SJ7 tube to see if it can handle a 100k load, and it seemed to be able to do it well. I did the bandwidth sweep and did not see any attenuation in the audible range. The B+ was 300V, the plate resistor was 47k, and the screen was set at 75V with Zener diode. I had a 1k potentiometer with a 100 Ohm resistor in series on the cathode as such:
With 75V on the screen, the 47k DC load line went right through the knee of the curve. I noticed the 1k sine wave had the characteristic 2nd order distortion with flattened bottom curve and peaked upper curve when I biased the tube to get a plate voltage of 150V. When I turned the cathode pot down, at 150 Ohm of total resistance, the sine waves evened out and became nice and symmetrical. The plate voltage was around 90V. The input signal was 2V p-p. Output level across the 100k load was about 120V p-p. The upper and lower peaks didn't look flattened, but I can't tell for sure. I have a very rudimentary scope so I can't export the waveform or do FFT. I tried it with a bunch of different tubes and had the same results. It looked like the 6SJ7 likes about 4.5mA. Can someone with proper gears check the circuit and see how much distortion there is? Thanks.
6SJ7, same as most tubes, likes any ample current. "Ample" depending on supply, load, and THD criteria. It can't be very fussy, because US broadcasters used the 6J7/6SJ7 for EVERYTHING under a part-Watt. (Even for triode. The 6J5 was very much a 6J7, but for broadcasters it was simpler to just keep the pentode in spares-stock.)
The amplifier tables are good authority.
6SJ7 will drive 100K very well. Without the extra mA or the Zener.
You can use REW, https://www.roomeqwizard.com/
It's spectrum analayser funtion not only display FFT abut also the distortion. You need only to make suitable adapter from the output to line input of sound card. Here I give you my sim prediction.
  • 6sl7 test.log.txt
    6sl7 test.log.txt
This is my version of line input attenuator for power and line preamp. The output level will be limited as clamped by zeners to about 1.2Vp accepted by line input, DC blocking capacitor is used to avoid passing DC. Some sound cards (in the low end PC) has phantom spectrum even without input so be aware.
  • loadbox.asc
    loadbox.asc
Installed REW, got everything hooked up. First checked the signal generator and the sound input device. Harmonic distortion was less than 0.005% across the board, so everything was good. 300V supply. For the setups without the Zener shunt, the screen was bypassed to the cathode with a 0.47uF cap.
RpRkRsTHD %2nd3rd4th5th
47k150R120k, 75V Zener2.711.472.170.680.11
100K500R120k, 75V Zener129.247.450.691.13
100k500R330k (67V)5.684.303.361.420.60
100K500R270k (75V)6.591.945.961.920.17
100K500R470k (52V)9.839.641.770.730.33
39k137R120k (90V)2.131.011.740.660.18
47k498R101k (135V)2.050.781.770.650.20
47k477R143k (113V)4.003.970.500.0940.064
The last three were done with a pot on the screen and a pot on the cathode. The 6th and the 7th ones were tweaked for the lowest THD. The last one I hooked up to a 6AV5GA, UL with cathode feedback at 60mA and tweaked the pots until it sounded the best.
Post #10 is a nice data set. But no mention of output voltage
signal level other than >100V p-p. Am I missing something??
For sake of comparison all tests of a series are usually run at
the same level, say 100v p-p.
These results are similar to what I got in another thread
where I used a plate load of 75K.
The AC Load vs the DC Load on the driver plate is always a concern, especially at higher levels.
The difference needs to be small as possible. Something to be careful of when driving a fixed
bias power tube. And always increases D%.
