icepower 50asxse case options?
Hi, Im looking for a cheaper alternative than the ghent Audio pre made case kit for the ice power modules. Looking to build one with the 50asxse board and I find it crazy the enclosure is as much as the board. What are some good alternatives, preferably with precut back for speaker posts etc. Also I have a case from a class D amp Im not using, its for the TPA3255 and reason why that wouldnt work?
HI, Yes Ive watched lot of his videos and his ventures into Class D amps. He sells a kit and a case but its also over 100 bux.
Yes that’s true but could get something done locally like that.
I got my case made locally buy having it laser cut and than bent on a manual press
You could see diyaudio shop they have small cases for the ice amplifiers
