My dac has a potent I/V stage, so gain is not required. I would prefer to use a tube rectifier.For these words in the title
You need some amplification (gain)
Buffer have no amplification. It is about 1X.
So with tubes buffer will sound more neutral and lets say natural.
But not "warm".
I dont see te point to supply tube device with solid state elements?
Tube power supply is more logic solution. If the goal is sound...
I am not looking for a transparent buffer. Warm, smooth and lush is what I require. Can this not be gained with the warmest parts?Then you will fail miserably because you are leaving out 99% of the important sound chain.
You are missing the tube preamp, its built in classic (and probably imperfect) tone control), phase inverter, Power tubes, output transformer .... "almost nothing" 😉
In fact, I doubt the classic tube amp even includes a buffer ... what for?
The old style amp will strongly colour the sound, and in many ways; buffers are designed to "do nothing" if at all possible.
Thinking than inserting a "do nothing" (or almost) box with a glowing filament tube between your (presumed) digital source and your (presumed) Solid State (even Class D) amplifier will achieve what´s asked for in the OP is simply Magical Thinking
You want what´s on the OP? ... fine with me, just build what you describe there and play vinyl records ... that´s The Real Thing [tm]
Building 1% of that, specially the flattest less distorted part of it? ..... think again.
The amp I currently use the dac with is a Sony GX900ES reciever. My speakers are a pair of Acoustat Spectral 11's.
Will I need something more to achieve my goal? A tube amp perhaps?
BTW, I do have a turntable for serious listening. The dac is for my computer.
First, a question. Is it possible for you to reduce the gain of your I/V stage, so that output stage doesn’t have to be unity gain? I think you’ll find that the majority of circuits which feature the sort of subjective characteristics you are looking for are above unity gain. Probably having something to do with the distortion character via a unity gain buffer, versus that of an otherwise similar stage with gain.
The H2 generator project might be what you’re after. The diy audio store even sells kits https://www.firstwatt.com/pdf/art_h2.pdf
1. It would be possible to attenuate the output with resistors, yes.
2. Adding harmonic distortion would do nothing to alleviate the fatigue of digital.
I am looking for a cost effective, and hopefully simple solution. But building amps and preamps is certainly something I can do.
I have been thinking about building a tube preamp (Marantz 7 clone?), and Class A solid state amp (Accuphase A60 clone?). Or maybe an integrate tube amp? I just need the funds.
You may want to check out the WOTS-LeGrande diy pre-amp by ‘marigno’. WOTS = (Warmth Of The Sound). I have NOT heard it myself, but his design goals seem to well align with your own. As designed, marigno (Fabrizio) says the gain is +20dB, which is why I had asked about that. The design is a relatively simple TRIODE-MOSFET hybrid, and shouldn’t be too challenging to build. In his thread you’ll also find the schematic for a solid-state version of the LeGrand, a JFET-MOSFET hybrid. Fabrizio’s subjective description of the sound character speaks for itself, and can be found within his starting post. Link below.
https://www.diyaudio.com/community/threads/warmth-of-the-sound-wots.380373/#post-6873366
This is a common modern fallacy. Any change to a signal that's not a linear multiple is a distortion. There is no such critter as "warmth" or "tone" - these good qualities come from the lack of flaws, and are not something that can be added in, or that the lack of can be corrected by more manipulation (distortion). Simple entropy.2. Adding harmonic distortion would do nothing to alleviate the fatigue of digital.
All good fortune,
Chris
Cool.I am not looking for a transparent buffer. Warm, smooth and lush is what I require. Can this not be gained with the warmest parts?
Problem is that in principle Buffers "are" quite flat and clean.definitely flatter and cleaner than any normal Tube amp.
There is not such a thing as a "warm sounding part", unless grossly defective.
Parts by themselves have no "sound" and in any case do not even work on their own, but as part of a circuit.
Claims that a single part, such as a capacitor or resistor, just because of being present, and with no further calculations can make sound warm - smooth - sharp - defined - cold - clinical - whatever are ludicrous to put it mildly.
Yes, unscrupulous sellers make those claims all the time (or even wilder ones), what else can they say about something that otherwise performs like a million others?
Problem is that those siren songs are attractive to many.
Well, I have decided that instead of putting anymore time, money and effort into improving a fatally flawed format, I am here to declare that I am really and officially done with digital playback for good.
I instead want to concentrate my efforts into building a warmer, more musical phonostage (with tubes of course). Any projects I should look at?
Yes, true paper in oil, not metalized plastic in oil.They are oil caps?
What is the warmest, smoothest and most lush phono stage projects that you have encountered? Good air and space with no fatigue is essential.
Will an EAR 834 clone satisfy my requirements?
Care to tell me why?This must be the funniest hi-fi question I ever heard.
In my amateur experience, system synergy, including cart, is most important for non-fatiguing sound. You might just have to build it and see how it turns out.
To answer your original question and hopefully be helpful, the most non-fatiguing phono stage I've built was http://www.hagtech.com/pdf/cornet2.pdf. I would personally call it "smooth". I wouldn't personally call it "lush". I find it non-fatiguing. The designer has released later versions (v3) without the original tube rectified high-V power supply. I think you'd have to p2p if you wanted to make V2.
Sorry, I'm not directly familiar with the EAR.
I have good experience from :What is the warmest, smoothest and most lush phono stage projects that you have encountered? Good air and space with no fatigue is essential.
merlin's
Right now out os sock but it will be back
Do you have the parts list and build plan?
Lots of people crave such a sound. Music should be rendered inoffensive, right?
Passive parts are often sufficient. Carbon comp resistors, Pio caps, NOS electrolytics, old PS chokes. Tube/Germanium/Selenium rectification. Lack of active regulation. And of course, a Denon 103 🙂
- Tubes / Valves
- How to build a warm, smooth and sweet tube buffer
