USA amps MD 1D
Hi all
Amp came with burned power supply. 70n06 mosfets with 47ohms gate resistor and two pnp A1266 drivers. I changed them with 3205.
Amp is pulling too much current on idle. I removed mosfets belongs to one transformer the other transformer that is producing small voltages works good Amp came on and gave good output oscillations.
But as soon I replace mosfets for next transformer amp pulls plenty current. I removed one mosfet from each bank of the same transformer and amp works good. So it driving 2x2 mosfets good but can't drive 3x3 mosfets. What I can do to solve this issue.
How do the drive waveforms on the gate legs of the FETs compare between the FETs of the two power supplies?
Attaching pictures of waveform when 2x2 mosfets and when 3x3 mosfets.
First picture when 2x2 mosfets are used same waveform in both banks. Second waveform is of one bank when 3x3 is used. Third is from another bank when 3x3 is used.
