Your favorite smaller size compression driver
What is your favorite smaller size 1" compression driver?
I need a great sounding driver (preferably under 75mm / 3" dia) to pair with a 6" mid, crossing above 3k. HF extension is important.
Some drivers that stand out -
  • B&C DE7 (yes, it has a 3/4" throat)
  • Lavoce DN10.142 (only 60mm diameter and goes pretty low)
  • Lavoce DF10.142LK (a little too big but sounds good enougn to make it work)
  • Selenium ST200 (a super tweeter, but it can cross fairly low)
Any other drivers fitting my criteria that I'm missing?
The newer BMS5530ND are smaller at 72mm OD, they are a super solid little thing in your hand with the Neo magnet designed for close spacing in line arrays. The response is fairly typical of BMS having a peak around 18K before dropping off, but they look much cleaner in the last octave than the lavoce do.
Reactions: profiguy
BMS 4552nd. 85mm dia and can cross at 1KHz in the right horn at prosound levels.
Why does the compression driver need to be so small?
Its going to go in a very tight space on a.baffle that use to be a large 2 way, turning into a 3 way to fix lack of HF extension. I've only got about 3 inches to play with, so I have to make my own WG from plywood and 3d printing.
This one looks very promising at only 60mm diameter.
Reactions: jotom750
B&C's DE360 ring radiator shows nice HF extension on the factory data sheet, but I have not seen independent measurements.
I've used that one and like it, but it doesn't sound that great down low. Probably a trait of being a ring radiator. Up high is nice and a bit euphoric, like other ring radiators tend to be.
The PRV D260 MR-Y is a JBL 2407 copy internally and sounds almost the same for only 50 bucks. I've used this one in alot of compact 2 way stuff with a 6 or 8" midbass. Good driver.
Thanks - That Beyma is also interesting. Rather high THD in that test, but mostly even order.
Don't forget that the harmonic distortion in that test is measured at 104dB/1m, so I don't call that THD level high at all, and it's not "mostly" even order, but it's exactly only 2nd harmonic (the least intrusive one, the 3rd HD is too low in level to affect the THD curve.
Reactions: profiguy and Pano
