Texas RC4558
Probably you're right! Didn't think much when i asked the question because according to a large number of people it is the 'worst opamp ever'!!
Although i've much better opamps in my possession but the noise figure of 4558 is quite good. Do you recommend it for gain stage? I do not need more than 1-2 Vrms approx. Also i think i can use it for unity gain buffer, will it work well there? 🙂
Huh… serves me right for not reading very well, I read this as the RC4580… which is a different opamp.
Still, in many cases an opamp is an opamp and will work perfectly. Give your 4558 a try and see what happens, I suspect you’ll be pleasantly surprised.
Anyway....my question remains unanswered 😒
Says people who never ever designed anything but read lots of Forums, and copypaste one another.
File them with those emphatically state "Mercedes Benz is cr*p, Volvo is best" (substitute brands as ylu wish) ... and drive a rusty shot rings oil burning 70s clunker 😉
I usually see the 4558 in some incarnation in bargain-basement lowest-bidder electronics
Correct that to: "I see them*everywhere*, as in everywhere, including cheap generic stuff.
You´ll also see lead-tin solder, plastic covered wire and fiberglass base PCBs all over the place, including cheap stuff ...... does the phrase "Industry standard" ring a bell?
Were better Op Amps made later?
You bet.
Does ir mean they are cr*p?
No way.
much better than dual 741(improved).
Not even comparable to 741, BUT you had to mention it in the datasheet simply because until then 741 was THE standard.
Mentioning compatibility was a BIG sales point.
For filters i think tl0 series fet opamps are good.
That´s a blanket statement if I ever saw one 😉
It was answered in post #4 (i.e.: it was improperly formulated)
Also very effective in ......
Stuff performs well if dsigned within its limits-
RC4558 is a workhorse and performs VERY well if asked for, say:
* Gv 1X to 50X
* voltage out up to 5 or 6 V RMS
* load 2k or higher
* <1M input impedance
* general purpose quite good noise performance
which covers LOTS of practical applications.
Reactions: NanoFarad
I do not recommend 4558. Although waste is a bad behavior.
And the operational amplifier does not have much difference in practical application
But I still recommend using 4580 instead of 4558.
Maybe we will waste a little money. But it will save a lot of time.
