Lots For Sale
Please check this post for complete list of all parts still available
10x C2547 no idea why I purchased these - £5 the lot
6x Geree DC-DC Boost converter 10A 250W (https://www.diyaudio.com/community/threads/aksas-lender-preamp-with-40vpp-output.314563/post-5260733 post 316) - £8 each
2x Selectronic r-type transformers. 30v with dual 24v secondaries - £20 each
1x pair DLH amp boards (https://www.diyaudio.com/community/threads/dlh-amplifier-the-trilogy-with-plh-and-jlh-amps.311567/) - £10 the pair
1x pair of F3/F3J boards - £15
1x pair of LU!014D matched by mbrewennwa - £18 per pair
2x volume/selector knob bakelite long design including grub screws - £8 each
1x complete F3 Amp boards, power boards and transformer (see image for transformer details) - £100
Parts Just Added post 8:
1x Salas B1 Mezmerize board. Dusty as its been an age since I used it so sold as seen - £50
1x Academy Audio VCU board Rev 01 & remote - £45
2x ConnexElectronic SMPS300REh 230v version with 24V output (18v secondary output) for use with FirstWatt Amps - £60 each
Sensible offers on multiple items considered
I'm happy to help out (within reason) on postage on the heavy items
10x Geree DC-DC Boost converter 10A 250W (https://www.diyaudio.com/community/threads/aksas-lender-preamp-with-40vpp-output.314563/post-5260733 post 316) - £8 each
1x Pair of rudi_ratios ACA with Cap-Mx onboard - £8 the pair
1x pair Elvee & diegomj1973 Denoiser boards from tombo56 - £8 the pair
1x F5 Kit with boards, matched mosfets and all jfets- £45
1x Amp5 though hole kit from 41Hz - £25
2x Selectronic r-type transformers. 30v with dual 24v secondaries - £24 each
1x Cap-Mx boards, 1 complete one bare - £15
1x DLH amp boards - £10 the pair
2x pair of LU!014D matched by mbrewennwa - £20 per pair
2x bakelite long pointer including grub screws - £15 each
1x F3 Amp boards, power boards and transformer (see image for transformer details) - £120
1x ACA SV13 Kit - Makes complete L&R channels. I only opened for photographs.
Contains as per the listing (https://web.archive.org/web/2016031...products/amp-camp-amp-kit?variant=14849115012):
  • Printed Circuit Boards
  • Transistors including Linear Systems's JFET's and IRC MOSFET's
  • Vishay/Dale Metal Film Resistors
  • Elna Silmic ll and Panasonic Capacitors
  • Bourns Potentiometers
  • Rocker Switches and LED's
  • Keratherm® insulators
  • M3 board mounting standoffs, w/ bolts and washers
  • Mounting bolts for Mosfets w/washers, high quality keratherm insulators
  • Gold plated Speaker Terminals and RCA Jacks
  • Power Connector Jacks
  • Wire
  • 2 laptop style power supplies suitable for the project
All you need to add is the heatsink/casework
Price reduction to £80
More Parts Added
