305Vdc HV regulator adjustable via zener diode too slow 7seconds
I try simulate 305VDC HV regulate supply adjust by change value of Zener diodes normally 75V zener. To use with 6sn7 and 45 total load is about 86mA
the problem is it take almost 7 seconds to get 305VDC.
How to solve problem?
if anyone can help provide 305vdc HV reg, will be much appreciate
thx
2SK3564 of Pspice not compatible to LTspice. How to convert to compatible value? Thank you.
  • (C) Copyright TOSHIBA CORPORATION 2017
  • Date: 28/06/2017
  • File Name: 2SK3564.lib
  • Part Number: 2SK3564
  • Parameter Ver.: Ver.1
  • Simulator: PSpice
  • Model Call Name: NMOS_2SK3564
  • TNOM: 25 degree
  • Pin Assign: 1=Drain 2=Gate 3=Source
* Operation of this model has been verified only on the OrCAD.
.SUBCKT NMOS_2SK3564 1 2 3
M0 1 22 3 3 smsmosfet
  • L = 5e-06
  • W = 0.03
  • AD = 3e-08
  • AS = 3e-08
  • PD = 0.06
  • PS = 0.06
D0 3 1 DDS1
D1 3 1 DDS2
D2 2 10 DGS1
D3 3 10 DGS2
R2 10 2 1E+009
R3 10 3 1E+009
RG 2 22 13
.MODEL smsmosfet NMOS
  • LEVEL = 7
  • MOBMOD = 1
  • CAPMOD = 3
  • NOIMOD = 1
  • TOX = 1.5e-08
  • XJ = 1.5E-007
  • NCH = 1.7E+017
  • NGATE = 0
  • RSH = 0
  • TNOM = 25
  • VTH0 = 3.3121
  • VOFF = -0.08
  • NFACTOR = 1.056
  • U0 = 1985.7966
  • K1 = 0.5
  • K2 = 0
  • K3 = 80
  • K3B = 0
  • W0 = 2.5E-006
  • NLX = 1.74E-007
  • DVT0 = 2.2
  • DVT1 = 0.53
  • DVT2 = -0.032
  • DVT0W = 0
  • DVT1W = 5.3E+006
  • DVT2W = -0.032
  • DWG = 0
  • DWB = 0
  • UA = 7.3367e-09
  • UB = 5.87E-019
  • UC = -4.65E-011
  • VSAT = 38144.4502
  • A0 = 0.28138
  • AGS = 7.4506
  • B0 = 0
  • B1 = 0
  • KETA = -0.047
  • A1 = 0
  • A2 = 1
  • DELTA = 9.5046e-05
  • RDSW = 93000
  • PRWG = 0
  • PRWB = 0
  • WR = 1
  • CDSC = 2.4E-004
  • CDSCD = 0
  • CDSCB = 0
  • CIT = 0
  • ETA0 = 0.08
  • ETAB = -0.07
  • DSUB = 0.56
  • PCLM = 1.1514
  • PDIBLC1 = 0.39
  • PDIBLC2 = 1e-05
  • PDIBLCB = 0
  • DROUT = 0.56
  • PSCBE1 = 4.24E+008
  • PSCBE2 = 1E-009
  • PVAG = 0
  • ALPHA0 = 0
  • ALPHA1 = 0
  • BETA0 = 30
  • NJ = 1
  • JS = 0
  • XPART = 0
  • CGSO = 3.525e-08
  • CGDO = 3.7238e-13
  • CGBO = 0
  • CGDL = 9.9997e-08
  • CGSL = 2.5774e-09
  • CKAPPA = 0.16384
  • CF = 0
  • CLC = 1E-007
  • CLE = 0.6
  • VOFFCV = 0
  • NOFF = 1
  • DLC = 0
  • ACDE = 1
  • MOIN = 15
  • CJ = 0
  • CJSW = 1E-012
  • CJSWG = 1E-012
  • PB = 1
  • PBSW = 1
  • PBSWG = 1
  • MJ = 0.5
  • MJSW = 0.33
  • MJSWG = 0.33
  • AF = 1
  • EF = 1
  • KF = 0
  • UTE = -1
  • KT1 = -2.45
  • KT1L = 0
  • KT2 = 0.022
  • UA1 = 4.31E-009
  • UB1 = -7.61E-018
  • UC1 = -5.6E-011
  • AT = 3500
  • PRT = 250000
  • XTI = 3
  • TCJ = 0
  • TPB = 0
  • TCJSW = 0
  • TPBSW = 0
  • TCJSWG = 0
  • TPBSWG = 0
  • DWC = 0.0082616
.MODEL DDS1 D
  • TNOM = 25
  • IS = 5.8251e-10
  • RS = 0.14804
  • N = 1.4
  • CJO = 5.3e-10
  • VJ = 0.4
  • M = 0.59
  • XTI = 3
  • TT = 1.78e-06
  • BV = 900
  • IBV = 0.01
.MODEL DDS2 D
  • TNOM = 25
  • IS = 5.8251e-10
  • RS = 0.14804
  • N = 1.4
  • CJO = 1E-15
  • VJ = 0.7
  • M = 0.3
  • XTI = 3
  • TT = 1.78e-06
.MODEL DGS1 D
  • TNOM = 25
  • IS = 1E-015
.MODEL DGS2 D
  • TNOM = 25
  • IS = 1E-015
.ENDS
  • Date: 28/06/2017
  • Simulator: PSpice
  • TNOM: 25 degree
  • L = 5e-06
  • W = 0.03
  • AD = 3e-08
  • AS = 3e-08
  • PD = 0.06
  • PS = 0.06
D0 3 1 DDS1
D1 3 1 DDS2
D2 2 10 DGS1
D3 3 10 DGS2
R2 10 2 1E+009
R3 10 3 1E+009
RG 2 22 13
  • LEVEL = 7
  • MOBMOD = 1
  • CAPMOD = 3
  • NOIMOD = 1
  • TOX = 1.5e-08
  • XJ = 1.5E-007
  • NCH = 1.7E+017
  • NGATE = 0
  • RSH = 0
  • TNOM = 25
  • VTH0 = 3.3121
  • VOFF = -0.08
  • NFACTOR = 1.056
  • U0 = 1985.7966
  • K1 = 0.5
  • K2 = 0
  • K3 = 80
  • K3B = 0
  • W0 = 2.5E-006
  • NLX = 1.74E-007
  • DVT0 = 2.2
  • DVT1 = 0.53
  • DVT2 = -0.032
  • DVT0W = 0
  • DVT1W = 5.3E+006
  • DVT2W = -0.032
  • DWG = 0
  • DWB = 0
  • UA = 7.3367e-09
  • UB = 5.87E-019
  • UC = -4.65E-011
  • VSAT = 38144.4502
  • A0 = 0.28138
  • AGS = 7.4506
  • B0 = 0
  • B1 = 0
  • KETA = -0.047
  • A1 = 0
  • A2 = 1
  • RDSW = 93000
  • PRWG = 0
  • PRWB = 0
  • WR = 1
  • CDSC = 2.4E-004
  • CDSCD = 0
  • CDSCB = 0
  • CIT = 0
  • ETA0 = 0.08
  • ETAB = -0.07
  • DSUB = 0.56
  • PCLM = 1.1514
  • PDIBLC1 = 0.39
  • PDIBLC2 = 1e-05
  • PDIBLCB = 0
  • DROUT = 0.56
  • PSCBE2 = 1E-009
  • PVAG = 0
  • ALPHA0 = 0
  • ALPHA1 = 0
  • BETA0 = 30
  • NJ = 1
  • JS = 0
  • XPART = 0
  • CGSO = 3.525e-08
  • CGDO = 3.7238e-13
  • CGBO = 0
  • CGDL = 9.9997e-08
  • CGSL = 2.5774e-09
  • CKAPPA = 0.16384
  • CF = 0
  • CLC = 1E-007
  • CLE = 0.6
  • VOFFCV = 0
  • NOFF = 1
  • DLC = 0
  • ACDE = 1
  • MOIN = 15
  • CJ = 0
  • CJSW = 1E-012
  • CJSWG = 1E-012
  • PB = 1
  • PBSW = 1
  • PBSWG = 1
  • MJ = 0.5
  • MJSW = 0.33
  • MJSWG = 0.33
  • AF = 1
  • EF = 1
  • KF = 0
  • UTE = -1
  • KT1 = -2.45
  • KT1L = 0
  • KT2 = 0.022
  • UA1 = 4.31E-009
  • UB1 = -7.61E-018
  • UC1 = -5.6E-011
  • AT = 3500
  • PRT = 250000
  • XTI = 3
  • TCJ = 0
  • TPB = 0
  • TCJSW = 0
  • TPBSW = 0
  • TCJSWG = 0
  • TPBSWG = 0
  • DWC = 0.0082616
.MODEL DDS1 D
  • TNOM = 25
  • IS = 5.8251e-10
  • RS = 0.14804
  • N = 1.4
  • CJO = 5.3e-10
  • VJ = 0.4
  • M = 0.59
  • XTI = 3
  • TT = 1.78e-06
  • BV = 900
  • IBV = 0.01
.MODEL DDS2 D
  • TNOM = 25
  • IS = 5.8251e-10
  • RS = 0.14804
  • N = 1.4
  • CJO = 1E-15
  • VJ = 0.7
  • M = 0.3
  • XTI = 3
  • TT = 1.78e-06
.MODEL DGS1 D
  • TNOM = 25
  • IS = 1E-015
.MODEL DGS2 D
  • TNOM = 25
  • IS = 1E-015
.ENDS
psice is happy with "+" being used to split models on lines but I found that never works for LTSpice so I reformat:
Code:
.SUBCKT NMOS_2SK3564 1 2 3 M0 1 22 3 3 smsmosfet L=5e-6 W=0.03 AD=3e-8 AS=3e-8 PD=0.06 PS=0.06
D0 3 1 DDS1
D1 3 1 DDS2
D2 2 10 DGS1
D3 3 10 DGS2
R2 10 2 1E+9
R3 10 3 1E+9
RG 2 22 13
.MODEL smsmosfet NMOS LEVEL=7 ... do the same here for all bulleted (with a "+")
.MODEL DDS1 D ... again here.
.MODEL DDS2 D ... again..
.MODEL DGS1 D TNOM=25 IS=1E-15
.MODEL DGS2 D TNOM=25 IS=1E-15
.ENDS
Leave the Dn and Rn etc on separate lines as I've shown above. It may be that LTSpice doesn't like the LEVEL=7 command, it's been a while since I did any LTSpice model programming.
I see the SK3564 datasheet doesn't have SOA chart which is a bit concerning. The DC operation at HV will lower the current capacity then typically they need derating with temperature. None of that information is in the SK3564 datasheet which may prove a limit that doesn't exist in LTSpice. You could use key+mouse click on the component to get a wattage graph instead of voltage. I don't know that on the PC as I used the Fn key on the Mac.
EDIT: also LTSpice may not like the e+009 or e+08 instead I've reformatted to e+9 etc in above.
Reactions: supernut
Code:
.SUBCKT NMOS_2SK3564 1 2 3 M0 1 22 3 3 smsmosfet L=5e-06 W=0.03 AD=3e-08 AS=3e-08 PD=0.06 PS=0.06
D0 3 1 DDS1
D1 3 1 DDS2
D2 2 10 DGS1
D3 3 10 DGS2
R2 10 2 1E+9
R3 10 3 1E+9
RG 2 22 13
.MODEL DGS1 D TNOM=25 IS=1E-015
.MODEL DGS2 D TNOM=25 IS=1E-015
.ENDS
EDIT: also LTSpice may not like the e009 instead I've updated to e9 in above.
Thank you so much i will try
I've just made an update/comment on the reformatting of leading zeros in the e+009 etc if, after the new line reformat, that doesn't work try the e reformat. If you look at the log (the Mac it's ctrl+L iirc) you'll see any issues the parser had at the top. I've had LEVEL issues before - that is more involved and it's easier to search for a new compatible model than play with the parameters and end up with a bad model.
Also want a gate protection diode across the mosfet source to gate to prevent it going positive should the caps discharge at different rates.
If you want a belt and braces a 1007 across the drain-source to prevent reverse polarity and not rely on the internal diode..
How does C3 bleed? (R1+R3 I assume)
