I guess you already have seen this datasheet: http://www.jogis-roehrenbude.de/Russian/6C33C/6C33C-B-6S33S-VExtendedDatasheetMB.pdf
Stay below 45W (for both anodes) and below 250V and service life will be a lot better. Go for a Ra between 800-1200 Ohm (preferable a transformer with an Rdc lower then 15 Ohm)
I personally like fixed bias for this tube but that is not the easiest way (steep tube, 1 volt differance on the grid makes a huge difference in current)
In this amplifier, I use the mode of 300-320 V, 55-56 W of anode power.
The maximum output power of the amplifier is more than 18 W, the output resistance is 1.25 Ohms at a load of 4 Ohms.
I can get an output of more than 20 watts, but I have to choose the tubes.
The sound is great.
https://sound-design-atelier.com/amplifier-2
The sound is great.
This is an autobias amplifier i guess.In this amplifier, I use the mode of 300-320 V, 55-56 W of anode power.
The sound is great.
Did you measered the linearity your self? From the datasheets it’s hard to tell.It is recommended to try to work with a half heater (half cathode), which can reduce the heat generation and the anode characteristics are more linear.
The difference cannot be great anyway because almost nothing changes, only 1 or 2 heaters are on the rest is the same. (Ri changes)
You can compare the curves below. Full heater on the left, half heater on the right.Did you measered the linearity your self? From the datasheets it’s hard to tell.
Because of different scales i cannot make any decisions about linearity.You can compare the curves below. Full heater on the left, half heater on the right.
No, there's an electronic bias systemThis is an autobias amplifier i guess.
What about tube life, 300-320V and 50-55W is not recommend.No, there's an electronic bias system
Several amplifiers have been working for about 10 years without problems. Electronic bias and soft start extend the life of the tubes many times over.What about tube life, 300-320V and 50-55W is not recommend.
Very good job!Several amplifiers have been working for about 10 years without problems. Electronic bias and soft start extend the life of the tubes many times over.
I am also very happy with this tube, very reliable. I used about 200-220V and 50W dissipation. Never had a broken tube (exept when i made a mistake myself). However, after 1000h i checked the amplifier with a new tube and i discovered that a new tube sound a little bit fresher. Just a little bit. The older tube was still good enough in my opinion.
This curve comparison is nice! However, the individual curves look like they were hand drawn using a curve ruler (take a look at the somewhat irregular spacing between the curves). These curves are not the best basis to assess the linearity. Are there any proper curves out there to compare full/half heater?
Thanks for scaling.Print at different scales and look through to the sunthrough pictures, if this is important to you.
The differences are to small and the graphs not super good so for me i go for the double filament.
My advice, if you need more than two or three watts for maximum listening volume, go with both sides, you will likely have better sound. I only need watt, so one triode is just fine.Thanks for scaling.
- Tubes / Valves
- 6C33C-B on 8W
