IMAX Sonics Speakers
Does anyone know the theory behind the speakers used in IMAX cinemas? I know they are made by Sonics and are designed to simulate a point source. What I want is some information on how such a layout works. The subs used are a massive bank of subs that face into a slot, why? I have included a couple of pictures of their speakers so you can see what I am talking about.
Lots of speakers are also located behind the screen. The screen actually has holes in them to let the sound pass through.
One of the reasons I can think of having bass facing the slot is to let the punch of the subs expand more evenly so that prople sitting near the speakers don't particularly feel the speakers are beside them.
Sound Re-Enforcement
Hi
For starters , you could go to the support / publication / user guide sections of jbl , ev , tannoy and read up on all they have abt installed cinema sound .
Attached here some other latest files on enclosed area sound re-enforcement to generate interest . - sorry tried uploading but the files exceed forums 195 kb limit
Plus a good book on acoustics - this is all to address ones interest in acoustics
regarding the imax , cant help much at the moment - if possible - could you get hold of the contract between imax & sonics -specially the acoustics & measurements I am posting a sample of acoustic measurements carried out prior installation in an auditorium as an sample (in the next post)
suranjan dasgupta
I've seen the Imax speakers up close and they have a lot of interesting details and show evidence of good design.
The first picture shows 2 concentric horns, the treble horn is in the center of the mid horn. You can see that the horns are designed to have assymetry with a downward firing directivity. The two units seem to share the same shape, one being a scaled up version of the other. This gives them identical directivity, as you would want. I assume the foam bits help with directivity and response.
Placing the horns in the center of the mid bass, and one horn in the center of the second, is just good practice for maximizing off axis performance (least variation).
Slot loaded woofers don't change performance much but do allow for a lot of cone area in a compact volume.
David S
My Sonics amps are actually Bryston 3BNRB amps with a different input module.
I'd assume they make their speakers using pro drivers from companies like Eminence and JBL etc. Then they design their own crossovers etc. My amp had active XO filters built in that were proprietary and removed before being scrapped. I would assume that much info on their speaker design is similar and they don't freely distribute their info on design.
I knew a guy who worked for IMAX. May still work for em. He used to be the guy to talk to. Everyone likes to talk a lil shop ... Maybe chatting up the sound guy at your local could garner some info?
Cool thanks. I followed some of those links over there, but haven't found what I was looking for yet. Will keep digging.
Hi Pano,
The answer is in post#93 ( I always suspected you were a bit ADD HA! ),
TW14MB said:
PPS Specs
Hello, I was at a local IMAX and thought the system sounded good, so I got some information from the local technical eng. I recently found this thread so thought I would share. He gave me a printout with this info, it does look like an overview sheet made by Sonics.
Much if this is known already, that the system is "Proportional Point Source" or "PPS" by Sonics.
3-way
x-over points
LF 80hz to 400hz Eminence 12" x4
MF 400hz to 7khz Eminence 8"
HF 7khz to 20khz Tad-2001
Text of interest:
"proprietary horns produce an asymmetric coverage pattern to closely contour with the seating arrangement of the theatre"
"The HF section uses a 1" compression driver produced by TAD (Pioneer)."
"The PPS loudspeakers operate in the frequency range of 70Hz-20kHz. All audio below 70Hz is delivered by the subbass."
I am a little confused by the last statement because of the xover at 80 mentioned in the other specs.
The sheet I have doesn't have OEM part numbers or detail on the subbass.
It was fun to talk to the eng. and learn more about the system.
I would also like to say THANKS to Jay Mitchell for making a great sounding system!!
I was one of the contributors in that thread. I dished out everything I learned after spending years trying to restore 3 of them.
The Midrange driver is an 8" Eminence. It's custom made and good luck getting recone kits for them. Nobody will help you out. It handles 50 watts IIRC.
It's somewhere between and 8" Alpha and Beta as Eminence told me.
Reactions: Pano
Hi
I have managed to acquire a pair of these, and although we have them working, and I have read all the other threads, has any ever had a fully working system, with the correct crossovers?
The crossover frequencies are only a very small part of the problem. What are the crossover types, what slopes are used, is any eq involved?
In measuring the 8" midrange, it is not linear anywhere near 7k. We are getting out of them at 2k.
Really like to hear these as they were meant to be.
Any additional info appreciated.
