Doug Self 16 dB passive attenuator
it's not clear to me what could be the values of R57 / R58 resistors of the "16 dB passive attenuator" illustrated by Mr. Self at page 394 of "Small Signal Audio Design".
The only hints reported my Mr. Self is that the input impedance of the attenuator is around 10 Kohm, and output impedance is 1.4 Kohm.
I looked for more details throughout his past articles in Electonics Word + Wireless World, and Linear Audio, but no success.
You guys have any ideas about those values?
Any help would be appreciated!
Angelo
R57 9k1
R58 820R
will give you -12dB
There is no need for -16dB but if you want, change the values using expensive special value resistors by all means.
R57 9k2
R58 800R
Here is an example of how to work out your actual values.
attenuator calculation
Thanks a lot for your super-fast response! So it seems Mr. Self left the solution "open" to reader's needs...
I can happily go with -12 dB as you suggested.
Best,
Angelo
