75ohm Definitive Technology sub help!
Hello,
I have a pair of Definitive Technology BP2000TLs that use 75ohm 15” subwoofer drivers and 500watt amps. The built in amps have finally died and the place I sent them too for repair said they can’t repair them. My guess is because of the 75ohm load. Anyways, I have a few question
1) I’d really like to fix the original amps. Does anyone know where I might be able to get them repaired. I’d really love to keep them as original as possible since I have always love how these speakers sound!
2) I completely understand that an amp is going to be putting out only a fraction of its rated power at 75ohms, but if I put enough power to them with they still perform. I kinda tested this theory using one of my Onkyo M-501s that are only 150w a channel. At a moderate volume and enough gain they do sound good. Anything beyond that and the amp just doesn’t have output to keep up. I was thinking of maybe using a D-class amp module, and modifying it to fix, but how big would I have to go for it to perform close to the original 500w amp?
3) if #2 is an unreasonable option, then I need to find a reasonably priced 15” 4 or 8ohm sub that will perform well in about 2.8 cft. enclosure with a port that’s 1.5” x 7”x 14”. I don’t have modeling software so any help here would be greatly appreciated!
Thank you in advance!
110% sure. The BP2000TLs all used 75ohm subs. It’s printed right on it and I personally measured it thinking the very same thing.
This is what I found on the manufactureres site:
BP2000TL Specifications: Dimensions: 9"W x 17"D x 50"H". Response: 15 Hz–30
kHz. Efficiency: 92 dB. Drivers: 4–61/2" cast-basket, bass/midrange drivers, 2–1" pure
aluminum dome tweeters in D’Appolito arrays, 15" sub w/500-watt RMS Infinite
Power Source amp. Connections: tri-wirable with separate five-way gold binding
posts and optional separate low level full range and LFE inputs. Rec. Amp.: 20–500
watts. Nominal Imp.: 4–8 ohms. Auto On/Off: Signal sensing. Finish: piano gloss
black or cherry. Weight: 125 lbs.
So what?
So what?
Not quite sure what you’re asking?
The impedance stated is 4-8 ohms, not 75 ohms.
Yes, that’s overall impedance 4-8 ohms. Please note it has an internal amplifier that powers the subwoofer, therefore the impedance of that subwoofer would have no effect on the overall impedance. It’s not a big secret in Def Tech circles that this speaker uses a 75ohm subwoofer. Plus it’s stamped right on it and I have personally measure both. As out of the ordinary as it is, it is FACT that they are 75ohm drivers.
Reactions: invaderzim
ok, found them now as spare part. I do not see any advantage in this proprietary impedance except protetection of sales of the brand.
I do understand your point of view, but still doesn’t help me in what I’m trying to accomplish. I’d like to keep the bass drivers if I can, just wondering if that’s possible with a “normal” amplifier.
500W/75 Ohms requires 193Vrms, i.e. +-300Vpk. In other words a full-bridge amp with 300V dc supply. This in fact could by powered directly from rectified 240V mains without transformer. Anyway there is little chance to find an adequate amp - I would try to repair the original amp.
