Leak 2030 crossover circuit diagram
All that it is necessary to do to the crossover you are refurbishing is to replace the ageing ELCAP bipolar electrolytic capacitors with modern equivalents.
For example, you may replace a 25 uF ELCAP with a modern standard value of 22 uF as the tolerance of ELCAPS wasn't tight in the first place.
If you are fussy, wire a 3.0 uF in parallel with a 22 uF to give 25 uF. https://wilmslowaudio.co.uk/mundorf-electrolytic-ecap-capacitors
The inductors and resistors can be left as is which will help ensure the originally intended sound quality.
This will be a pretty standard Leak/Wharfedale three-way crossover.
Can you provide a larger, sharper image of the crossover board than shown in my attachment?
A list of the capacitor, inductor and resistor values would be useful.
Thanks, jim04.
I found the attached image of the board on another diyAudio thread.
On this image we can see two resistors:
The small one is 2.7 ohm, 2.5 watt.
The large one is 15 ohm, 10 watt.
I'm with Nigel.
Since you have physical access to the front and rear of the crossover board you are in a good position to try roughing out the circuit diagram for yourself.
As a guide, the layout will be similar to that of the attached Wharfedale Linton 3XP crossover (courtesy of member system7).
(From top to bottom: tweeter; midrange; woofer.)
Thanks boys ... you are of course right but following the printed circuit as it squiggles around like a tray of snakes and switching my attention between the components on the front and the blobs of solder on the back makes me go cross-eyed and dizzy ;-)
