YAMAHA A-S300 transformer dead
Ok.
I think it's secondary dead,no 77.9v & 61.2v AC on CB104....
Hello.
Need help.
Amplifier YAMAHA A-S300.
The power transformer is dead.
Primare is shorted.
Fuse F1 blown.
Please help me if a can to adapt the transformer of NAD C315 for Yamaha.
Original Yamaha transformer is very expensive for this old Amplifier.
SM YAMAHA.
https://elektrotanya.com/yamaha_a-s500_a-s300.pdf/download.html
SM NAD
https://www.manualslib.com/manual/1186901/Nad-C-315bee.html
just rewind the primary ,is normal find a lab near you
btw if burn maybe diode /caps need a look
Schematic shows thermal fuse on primary. A Blown/open thermal fuse would not cause other
downstream fuses to blow.
Amp is probably in standby/protect so main transformer may not be energised. You probably
have a failed power supply, blown outputs or... Refer to the self diagnostic mode in the service
manual.
Check for charred/discoloured resistors around the power supply and voltage regulators also any signs of stressed capacitors (unlikely in a "new" item). Possibly a short to GND, you could try diode testing each regulator looking for a short????
