As per title i m looking 4 woofers with spec Fs no less than 25 hz and xmax 9 mm at least . Also 15 inch minimum . I m from Europe , Romania .
I have 4 NHT1259 woofers that I could sell. They are 12", Fs 20Hz, Xmax 13mm.
Spec can be found here: http://www.madisound.com/pdf/nht1259.pdf
I have 2- JBL K151's and know where you can get two more exactly like mine, re-coned by the same guy w the same kits. You'll have to do your own homework on the specs you need. In the US.
https://www.diyaudio.com/community/...mpnents-altec-jbl-emilar.388510/#post-7089066
Just puzzled, you want Fs to be high? Why.As per title i m looking 4 woofers with spec Fs no less than 25 hz and xmax 9 mm at least . Also 15 inch minimum . I m from Europe , Romania .
There s is a NO in front of less 🙂
So , to clear the air - FS 25 hz or LOWER , xmax 9 mm minimum and 15 inch minimum
4R or 8R?I have 4 NHT1259 woofers that I could sell. They are 12", Fs 20Hz, Xmax 13mm.
Where are you located?
