Mullard 5 10 Watt amplifier future build
Reactions: calpe
Are there a workshop in the area where you live? Make a drawing and ask the workshop how muck it costs to make a chassie? I like to build with aluminium. That because it is easy to work on, easy to drill holes in, etc. My amp chassie got aluminium with 1,5-2mm thickness. Start to make a plan over the parts you will need...capacitors, resistors, transformers, and so on. There are a lot of people out there who sells components, and many of us have to much lying around, and will sell/give away for "nothing". Where are you living? Find the right schematic on the intrnet. Look around you, use standard capacitors and resistors. Do not buy cheepish transformers, I am a fan of Hammond and use a 370HX and 1650E for output transformers, and chokes for the power supply. The chassie are 41cm x 29cm x 8cm, (w-d-h) and I think I found it near a trash-can? Probably have been a power supply, or something used in the PC-world? Just look around? Good Luck, https://www.diyaudio.com/community/threads/made-myself-a-el84-pp-tubelab-clone.381104/
Stenak, there are workshops near me, but it'll probably be cheaper to buy one
I would like to try and keep suppliers down as much as possible.
https://www.rapidonline.com/ seems to be a good choice to start with.
The 2x 1650HA + 1x 372JX are what? From where did you order them? £374 for just three items, is quite a chunk!
Transformers are the most expensive bits. I ordered them form Digikey.co.uk.
1650HA-> Hammond 40W push-pull output transformers 6600:8, a couple for a stereo amp. I wanted to use 6L6 tubes hence the choice of impedance.
372JX-> Hammond power transformer.
It was my first build, so I went for things that I was 100% sure would work fine, based on what I read here. These days I would not buy a power transformer, I'd use an SMPS.
Output transformers are always expensive, but if you do not need a lot of power then you should be able to get a decent pair for £100
