Volt BM2500.4 / Seos12 MTM
EDIT - Project revisited in 2025:
I've had a long running plan for a 2-way with a 10"/12" and Seos 12, originally planned with a Supravox 285GMF which I had but a couple of years ago I sold all the DIY bits so starting again.
https://www.diyaudio.com/community/threads/1-cd-w-seos-supravox-for-small-room.340786/#post-5963019
Over the past year, I've been assembling parts, with the Seos12, MiniDSP 2x4HD and now, a quad of Volt BM2500.4 16-Ohms.
Volt BM2500.4 by Robert Seymour, on Flickr
Volt BM25004 Comparison by Robert Seymour, on Flickr
Volt Seos by Robert Seymour, on Flickr
I had not originally planned an MTM but these four 16-Ohms BM2500.4s came up at a bargain price and although cosmetically challenged, they all measure really well and excellent matching! Only thing, with the grilles in place I can't measure the Vas with the DATSv2 by adding mass to the cone!
Cabinet wise, these always seem to be in ported enclosures but with such a low Qts, 0.25, they don't model well. I'm thinking possibly going sealed and then with their 8mm Xmax, applying EQ to bring the bass up. I have an ATC/Castle Classic subwoofer to fill in the last octave if required, and my new room will be around 16ft square so good size but not massive space to fill.
Had a chat with Volt, managed to gently prize off the grille of one cone. The cone had so much dust under the grille, 1/3rd of it (bottom when mounted I guess) had a whole matted almost felt like assembly of material that I took off, and using a slightly damp cloth, gently wiped away more dust from the cone. There is a little staining on the cone and some more engrained dust remains, mostly on the surround closet in this photo.
Spke with Volt again, they advised against a damp cloth as the cone doping is water based, and certainly against anything like isopropyl alcohol.
Any other ideas on what I could try?
Taken from the Volt website, suggested enclosure ideas.
https://voltloudspeakers.co.uk/loudspeakers/bm25004-10/
Maybe use the manufacturers data and see if it gives similar box dimensions when you model one of them with a suitable software packaged Once you have verified this just add the 2nd driver and see what the program then suggest. Two 10" volts per speaker should provide enough bass for most people.
Yeah I had seen the suggest enclosures, now I have one of the cones off I can measure the VAS.
If you can sensibly re form the grill and re paint them, I am sure you wont notice the bass cone discolouration.
I think your sticky sided tape is maybe the best and safest option. Unless anyone else knows another fool proof method of de dusting not using liquid cleaners, I would just accept this is the best you can get in terms of cone cosmetics.
Enjoy the bass.
Reactions: gwmorgan
Enjoy the bass.
Yeah I was thinking of rear mounting the bass drivers anyway, behind some fabric for an integrated grille.
Possibly might try a pet hair roller, see if that helps.
I did a quick CAD model of what I was thinking, based around just using the golden ratio for the boxes. The two Volt 10" in a ~20 Litre Sealed cabinet each, with the Seos 12 in the middle, covered with a grille cloth for a simpler look. Added in a generic ~100 Litre/12" subwoofer at the bottom. Idea around the modular design is I can then chop and change as the plan evolves rather than building all new cabinets again. Amp/Crossover will be a pair of Hypex FA123 I am in the processes of sourcing (Possibly BTL for the Volt drivers) and then can use the MiniDSP 2x4HD for the subwoofer(s).
For a sub, I still have my Castle ATC PA75-314 driver that's been rebuilt, could be an ideal candidate for a Tapped Horn subwoofer.
https://www.diyaudio.com/community/threads/atc-pa75-314-sub.386678/#post-7033465
where did you source the seos wave guide in the UK?
Never could justify the cost of the necessary quality measurements folks take for granted these days, but was blessed by being 'surrounded' with musical folks with good to extremely keen, hearing, so while I have to leave it for others to prove, they can definitely be audible IME when there's no screen/grill.
That said, IME it was only noticeable by females on smaller baffles relative to the huge ones that were the norm back then, so assume the OP's would be mostly cosmetic, but then you query only addressed the physics of the situation. 😉
