loudforce 2000.1 distortion
loudforce 2000.1 class D amplifier, the source is ok, the audio output is ok, however, the amplifier works for a minute and the sound is distorted and cuts off, no physical damage, I don't know where to start, everything looks good , Thank you
my source is 13.5 volts and 25 amps, when the amplifier distorts the rail voltage drops but the source does not drop below 13.2 volts, suddenly when the amplifier works well if it consumes more amperage and the voltage drops to 12 volts
hello perry, no, actually the problem is so intermittent that it works well when it wants to, not for time, I mean that when it works well it is only for a short period of time, but I doubt that it has to do with the heating of some component since the failure is constant and can occur from the power on of the amplifier.
sorry for my english, I'm using the translator.
