It's a tough job to please a woman![]()
Indeed so! After finding not enough distortion I turned to power supplies and realized I now had two TL431s in series with this design to get lower noise. So I wondered if there was some kind of interaction between those two shunts and added a damping 220uF capacitor across each and invited wifey for another listen. This time she didn't notice the imbalanced sound/distortion on piano. Hmm, that's progress 😛
The last step is - remove those capacitors and see if anything changes. What do y'all think the result will be?
How could I know?
I don't know your wife, GLOL!
On a more serious note, well done, whatever the outcome, again a small progress... they all add up!
Claude
Claude
I'm only looking for guesses, not knowledge!
BTW I just posted a little bit more progress on my blog. It is possible to 'overclock' TDA1387 by injecting some current into pin7 and get more juice out of it than the DS says. I've not pushed it very far yet but my first experiment shows a 50% overclock is possible.
TL431 can oscillate. See oscillation reference in the datasheet https://www.ti.com/lit/ds/symlink/tl431.pdf?ts=1653450587539&ref_url=https%3A%2F%2Fwww.google.com%2FIndeed so! After finding not enough distortion I turned to power supplies and realized I now had two TL431s in series with this design to get lower noise. So I wondered if there was some kind of interaction between those two shunts and added a damping 220uF capacitor across each and invited wifey for another listen. This time she didn't notice the imbalanced sound/distortion on piano. Hmm, that's progress 😛
and in the much more explanatory https://www.ti.com/lit/an/slva482a/slva482a.pdf?ts=1653463187100
This means depending on the Vak and the Iak, a capacitor -or better a resistor in series with a capacitor- may need to be placed across anode and cathode.
George
edit: They may not oscillate in static condition but require some form of load step change (e.g. percussion instrument playing)
Quote: BTW I just posted a little bit more progress on my blog
Link perhaps, couldn't find it
Thanks for sharing and all this, Richard!
Claude
Claude
https://www.diyaudio.com/community/forums/abraxalito.192/
Thank you George for the appnote, hadn't seen that before.
And some educational techno-porn
http://www.righto.com/2014/05/reverse-engineering-tl431-most-common.html
George
George
Any listening impressions or opinion of the very nice looking Dac yet?Very nice looking Dorati Dac
hi , because the two versions require very different voltages, i am waiting for my transformers to be delivered. What i have now is the op amp version, i have left my impressions in this thread itself.Any listening impressions or opinion of the very nice looking Dac yet?
i will be using the same psu regulation, same usb interface and also the same output caps (they are off the dac board) to compare between the op amp and discrete boards. But i need to use a different power transformer to avoid overheating my psu regulators. Good thing that the mechanical mounting footprint for both boards are the same.
Looking forward to your impressions @commstech . We have now got all the components for kits of Dorati but not PCBs yet, they might be delayed because of the Dragon Boat festival this weekend. So any day now when those come in we'll be able to open sales.
Here's the new thread for Dorati kits : https://www.diyaudio.com/community/threads/dorati-nos-dac-kits.387035/latest
Any updates on your new 12V Dorati power supply @commstech?
Hi Abraxalito, I have completed it on Monday evening after the transformer reached me last week on Friday. There was a delay in the delivery at the customs because i have opted for the wrong method of shipping. Should have chosen Sensitive Air instead of Economy Air shipping. Package was rejected and then reshipped. I have listened to it for 2 days to form an impression. I shall post this evening (my local time) when i get home from work.Any updates on your new 12V Dorati power supply @commstech?
have been having issues with certain websites (including diyaudio.com) intermittently since yesterday.
Sorry for the delay and thanks to Abraxalito for his patience. Finally settled down from some life and work matters and have some free time to write. As a background, I have Kubelik with opamp in the IV/output stage. Abraxalito, please correct me if i am wrong -- Kubelik has discrete transistors biased in class A at the outputs, in combination of Op amp stages. Recently, i received a new version with full discrete IV/output stage, which is now called Dorati. Kubelik works on 20Vdc and Dorati works on 15Vdc max, which prompted me to get a new transformer.
Upon firing up Dorati, the immediate impression is a more quieter and dark background. This is a very obvious difference from the Kubelik. This could be due to a less demanding power supply? I am using the same psu regulation on both dac. The Dorati presented a more solid imaging when i played Chinese orchestra music. More pin-point positions of the various instruments. I can feel that there is more depth in the soundstaging presented by Dorati as compared to Kubelik. To be more specific, there is more depth and space.
I played female vocals and listened. Again, the above observations. However, i feel that the singer actually took a couple steps back as compared to Kubelik. Instruments are more widely spaced apart, more resolution for Dorati - which sometimes i feel the Kubelik may slightly lack in when i compare it to my Soekris r2r dac. The Dorati does sound more extended in the frequencies when strings are played, better decay than Kubelik.
At this point of time, one may think the Dorati is a clear cut above the Kubelik. I will say no. The Kubelik has a quality that i like very much. It has more ambience to the music. It adds warmth and bloom especially in the mid and low regions. When complex passages like the Chinese Orchestra is playing, the Kubelik may not produce the bigger soundstage and separation of Dorati but let me say that the Kubelik has a very good control of the music - unfazed, there is no nervousness. The Dorati has a certain small degree of strain whenever i really push up the volume playing the orchestra, while the Kubelik has no sweat at all. This is something that the Kubelik impressed me since day one.
In general, the Kubelik has a more upfront and forward presentation versus the more backward and bigger presentation of the Dorati. the Dorati plays with more finesse, finer resolution , more hi-fi style. Kubelik is about warmth and control, good grip and bite on complex passages. I do believe the different output stages work done by Abraxalito attribute to a strong influence on the sonic outcome on the same dac implementation. I do believe both designs can work well on different systems and the individual's taste.
I hope this helps.
I hope this helps.
That's all very interesting - thanks for such a detailed review @commstech . I wonder whether the 'small amount of strain' of Dorati could be due to having a lower power supply voltage so the signal's closer to the rails. I will have a look into this - I specifically designed Kubelik to have lots of headroom, which is why it needs 20V. What supply voltage are you using on Dorati?
As regards the darker background of Dorati, I think this comes from deleting the opamp, I figure the transistors give it a lower noise floor.
- Vendor's Bazaar
- Kubelik NOS DAC kits
