Salas DCG3 preamp (line & headphone)
Here is a pic of MOSFETs.
Russellc
That's quite a range of tightness! 1 inch pound to 15 inch pound. No idea of how tight that is, typically I turn them snug, then a little more. I did notice improvement when loosening them, so I will adjust a bit like that. how small amount of "snuggness" can I get away with? i turn until it snugs, then more.
Let me try, otherwise the bar method will be used.
Russellc
Russellc
7-10 In lb seems good enough already in the chart. Finger tight is surprisingly powerful: https://en.wiktionary.org/wiki/finger_tight
Ok, backing them off, then snugging forward without the extra ump has them all quiet. Just turned until good snug, without the extra twist
like I would do an output mosfet on a power amp. I guess I will find out monitoring their heat with a laser thermometer tool.
I dont have this fuse on hand to replace so fireups will have to wait.
Russellc
Reactions: Salas
