How to remove XLR connector?
Hello,
I would like to replace some capacitors in my DAC and have to remove a Neutrik XLR connector for this.
Unfortunately, the connector faceplate is too large to pull through the housing bore. Is there a way to detach the connection plate with the two diagonally arranged holes from the connector?
Two photos showing the problem.
Kind regards
Achim
Deep gratitude for this info. Trying to remove the same connector from a Krell 250M power amp. I thought I'd share exact details on what modifications to make to the screwdriver to make it fit.
I filed down a cheap jeweler's screwdriver to the following dimensions. The key is that the tip must be smaller than the diameter of the hole. 90 degree CCW released the connector housing.
Shaft diameter=2.4mm
Blade width after filing down=1.2mm but could be wider
Blade thickness at tip=0.9mm
Pictures attached for clarity.
Reactions: lung
