100W Ultimate Fidelity Amplifier
Hello Mr. MILE, I have some questions:
NOTE ANY ERRORS IN THE DESIGN.
WATT RMS IN 8R AND 4R, WITH 300VA 50V-0-50V DC TRANSFORMER. WITH A PAIR OF 2SC2922/2SA1216 TRANSISTORS
I WOULD APPRECIATE IT MR. MILE
APEX AX-14
Hello friends,
I have a problem, I put together the AX14 and I have DC current at the output. I attached a photo, please I need help, I already measured all the transistors and they are fine, I checked all the resistors and diodes, everything is fine, please I need help, I don't know what else to check.
Los transistores de salida mjl4281a mjl4302a
driver mje15032G y mje15033G
Greetings
Hi everyone,
Very interesting thread even in 2022, I went through almost all of it 🙃
I want to ask about a replacement ksc1845. It would also be possible to use NTE electronic's type NTE2696 in this position?
Thank You!
@HRDSTL I have quite a few ksc1845 and ksa992 if you want to PM me. I personally would not trust a NTE without comparing the datasheet very closely, the specs tend to be generic and not specific to the task like ksc1845 would be
Reactions: HRDSTL
So the boards for the FH-9 XRK-MOD (2oz cooper) are already at home. Today I'll get to work and mount something...
Thank you all for the excellent work you have done.
Looking forward to hearing how you like the sound. I am not sure as I may have missed it, I have not seen anyone build this board yet, maybe you are the first?
Good luck!
