Full active system plus components - Yard sale!
Got a year till we move house so starting the clear out now!
I will take photos as I haul out the boxes from the loft over the next few weeks.
Finished components include:
Custom Install Audio SM15 - Studio monitors with Beyma 15 inch bass and 5 inch mid/top.
The Mid/top driver is an amazing Rapid Energy Decay (RED) flat coned, honeycomb driver... Crossover at 400Hz and flat to 18Khz!! Super accurate.
Can demo in high end system.... Amazing sound.
Can sell with full system including 4 channels (two stereo power amps - 15Kg each!) of high power / high performance class A/B amplifiers. £200 each.
Can also sell with DBX PA 2 active crossover. £250
These monitors are solid birch plywood laminated sheets ... Totally non-resonant and heavy... 22Kg.... Buyer collects or I can deliver up to 100 miles radius of St Neots PE19.
Two subwoofers (the metalic silver cabinets with Beyma 15 inch drivers) and Yamaha amplifiers.
DIY components include:
Everything from DDFA amplifier module to Beyma 5 inch drive units (16 of them great for line array) Audax drive units, 10 inch Focal kevlar bass driver, Manger drive units (need repair) cables, connectors and cases... Also going to Ebay some kit https://www.ebay.co.uk/itm/Overkill...-amplifiers-150-watts-into-8-Ohm/384909448651 plus see "other items"
PS some prices:
£300 per pair for the SM15 and SM10 studio monitors... Unless they sell for more on Ebay, early bird and all that!
Subs £200 each.
Amps £300 each (>£3,000 new!)
All the Beyma 5G40 Nd drivers are boxed and unused. £30.00 each or £ 20 each if you buy 10 or more.... £90 new! http://www.bluearan.co.uk/index.php?id=BMA5G40Nd_N
Sabaj amps £100 each (got two of them) hardly used.
DBX PA 2 crossover £200.
Lots of cables.... Literally every type from mains, speakers, RCA , XLR, silver, copper , optical, USB.... Even ethernet!
