Fostex FE206NV and Fostex Horn
Hello. My name is Cristian Peregrino and I am from Argentina.
I have a pair of Fostex FE206NV in a bass reflex (55 Liters tuned to the Fs) .
I plan to build some Horn.
I have three designs in my head. Karishima, Joan from The Frugel Horn and the one proposed by Fostex in the driver's data sheet.
Did someone build this box? What impressions do you have?
Thanks.
Christian
Reactions: 1 user
I found this on a Japanese blog. It looks a lot like the Dallas II. Will it also work for the Fostex FE206NV like the Dallas II? This box is easier to build.
Christian
No idea about that one, but the designer of the Dallas II did a lot of work to optimise it.
I did not find them difficult to build, you need some tools and a background with woodwork.
Like any build, take time, and care then things work out.
Reactions: 1 user
Hello Cristian,
Kinda late to this. I built the folded horn as sold by Madisound. Back then, the driver was the FE202EN. I am very pleased with them. The efficiency is amazing. A sub helps, but is certainly not required. Unfortunately, they are not currently available due to the high cost of materials. One can follow the plans on the Fostex site. In addition to responding to Cristian, the purpose of this missive is simply to join the conversation. I will say here, and on the amp forum, my delight with both the speakers, and especially my Akitika amp and preamp. They see frequent, high volume rock n roll, and in seven years have performed flawlessly. Dan is a great resource; always answering the phone or emails. The assembly manual is well-written. I especially like the reference to performing a "smoke test," before final work. I see above that a very positive reference is made to the new GT-104, as replacement for the amps using the LM3886. I would highly recommend anything from Akitika.
