Crossover point for 2 way
Midbass has some nasty peaking in 8-10 kHz area.
Tweeter has good Xmax plus higher power rating than midbass and its power rating will be increased by attenuation necessary to match efficiency of the midbass.
Taking that in mind I would go with fairly low XO frequency around 2000 Hz.
Thats some three times higher than tweeter Fs and some four times lower than midbass peak, so simple 2nd order will give enough rolloff to avoid any problems.
Reactions: Woofer87
Seeing the direction this is taking I'd also suggest 2nd order. It may help with the rising impedance, the baffle step and the peaking. For example, get your woofer values then increase the inductor value yourself to handle the baffle step.
Reactions: Woofer87
