12 inch woofer suggestions
I assume that LESS than 3.3 cf is okay, since you can always seal off unneeded volume?
Dayton Audio SD315A-88 (dual voice coil, so this is a 4 ohm speaker)
Dayton DS315-8 or DSA315-8
Peerless by Tymphany NE315W-08
SB Acoustics SB34NRX75-6 12" Woofer (This is out of stock at Madisound so not sure if this is obtainable
i agree with Wolf,
i used the dual 12” XXLS in my recent 3 way. I wanted a sealed cabinet so chose the P830845 variant.
2 woofers in 4 cu ft total hits about 92-93dB/2.83V. Be careful with sub 4ohm impedance if running passive crossover.
Hit 112dB; and I’m not even sure how to measure distortion at that level; because the room is vibrating like a earthquake/tremor that we sometimes get here in northern Australia.
there are other XXLS variants that you can use ported or with a passive radiator. Paper cone or aluminium cone.
the Dayton RSS315-HF8 is also reported very good.
but it depends-you’ve stated cabinet size and price; but how low do you want to go and what sensitivity do you want to hit ?
