Troels MUN17 design crossover topology
And you won't match them with calculators. Troels uses a full set of driver measurements, and then applies the electrical xover's transfer function to the acoustic response and inherent rolloffs the drivers have, whilst keeping the impedance and it's phase in check and making a safe load for an amplifer.
Electrically, they are 3rd on tweeter, and 2nd on the mid bandpass filter. However, there is a contour on the mid that likely changes its rolloff characteristics. The acoustic rolloffs combined will not reflect 3rd order slopes.
Reactions: waxx and Daphnary
Not to good to hear 🙂 I had a plans and now I need to reconsider lots of things ....
Then it's not Troels' design, and you're on your own. You can't substitute drivers for a given network, nor can you take a woofer network from one design and a tweeter network from another and put them together. The system consisting of the cabinet, drivers and their placement on the baffle (that is also not up for too much alteration), and the xover are all part of an optimized cohesive system that is defined for this one design and no other.
There is also no 'drop in' replacement 99% of the time when it comes to drivers and their boxes and xovers.
Troels has stated that it’s one of the few designs where driver choices chosen from the outset by Scan-Speak, IIRC.
Perhaps the NDA has expired. Perhaps they wanted to open source it. Either way, it sells more drivers for Scan-Speak.
