For Sale First Watt DIY F6 Amplifier
Things you have for sale.
Hey buddies!!
My diyaudio first watt f6 amplifier will is out for sale, it was assembled with up most care and sounds great, Lol damn great!!. All the component were sourced from diyaudio expect the chassis, it has more heat sink area than the first watt f6 chassis and is very high in quality.
Little description of the circuit: This F6 is a class-a mosfet power amplifier, with a jet driver stage, It utilises small signal transformer for the phase inversion, so both the output mosfet are n-channel,. However, this transformer greatly contributes to the overall sonic character of the amp which is very highly regarded and considered to be similar and having all the benefits and positive characteristics of a tube amp, and making some observers speculate that much of the positive (tube amp ) sound is the transformers, not the tubes. Lastly, the f6 is a regular kind of amplifier- a voltage source amplifier, which requires nothing out of the ordinary from the preamp or the speakers. Also, the power output is 25wpc into 8 ohm. 50wpc into 4 ohm.
I think this little description might help!!!
PRICE: USD725
SHIPPING WEIGHT: 35.00(lbs)
Mint condition and function well.
🤦‍♂️🤗@Vunce.
Lol, that's my fault here are pictures
Did you build it? If so, can you tell us a few things that we may not be able to discern from pics, please.
  • What JFETs - LS or Toshiba?
  • What output devices? If you got them from the DIYA store, they're likely the Harris parts, but can you confirm?
  • Any other mods / deviations from the 'typical' build? Antek AS-4218? What parts for rectification?
  • I see what I think is a DIYA soft-start board, but I don't see the accompanying speaker protect board. Granted, neither are necessary, but do you happen to have the speaker protect board still? Am I missing it in the pic?
I think this will provide some info for other prospective buyers, if I don't snatch it. 😀
Reactions: rjbond3rd
