Does B+ also determine power supply capacitor voltage rating?
Hi
I am trying to understand more about tube amps so I can eventually do some modifications to my own tube amp.
Do the power supply capacitors also need to be rated according to B+? So let's say B+ is 180V, are 180V of current going through the power supply capacitors or does it become 180V after it has already passed through them (if that makes any sense)?
I am in Europe so voltage from the wall would be 230V.
Cheers
The B+ voltage is in fact the DC voltage on the power supply capacitor connected there.
The input current from the transformer and diodes keeps the capacitor charged to the nominal voltage,
while the output tubes drain the charge. For a constant charge on the capacitor, the voltage V = Q /C,
where Q is the charge on the capacitor plate, and C is the rated capacity of the capacitor in Farads.
On average, the charge (and voltage) remain about constant, although there is some ripple in the DC voltage,
since the charging is not constant but occurs in pulses twice during every AC power line cycle.
You may want to experiment with this program to get a better idea of how it works.
https://www.duncanamps.com/psud2/
Reactions: Yoshimitsu
So what resistor value he should use as a load between B+ and ground to simulate a tube. At least in psud2 ?
Assuming the most demanding SS bridge topology will ask secondary transformer VAC x 1.41 voltage rating to choose the voltage rating and add the 20% for better life span. Say the secondary is 230 Vac, you got circa 390 Vdc which ask a 400 Vdc rated cap.
Minimalist answer for security again as involving the most demanding need i.e. 4 rectyfing diodes. Looks like the op did not understand this is not the load that dictate the cap voltage rating as he talked about voltage. But maybe he wanted to ask about capacitance in relation to load need. At this level the first answer should be to avoid him to put his hands first in HV power supply before having a better understanding cause it is possibly lethal. At least my feeling as a non native english reader in relation to the question and a technical noob myself.
As a technical noob myself this us what I understood from the question between lines.
There is a pdf from Hammond about secondary power traffo and rectifier w and w/o center tape topologies to see how voltage is outputed.
Btw, re read some old posts of Eva members and all about decoupling and knowing that we often make it in several parts between the load and the bridge, I have been understanding that capacitance and decoupling was all but simple !
