Fresh made DIY desktop Speakers named MoniThor (small but great sounding)
Drivers:
Peerless SLS-85S25CP04 - 4 Ohm
Ciare MT200 - 8 Ohm
Xover point: ~3000Hz
FB: 50Hz
Drivers:
Ciare MT200 - 8 Ohm
FB: 50Hz
Frequency response measured at the listening point, 70cm circa far from the speakers.
I don't like that dip at 130Hz, need to fix it... (or it could be my microphone's fault)
I've used 10mm MDF, for a small box I think it's thick enough, also the internal bracing gives some help.Looks like a great project! Are you using 1/2" material? Sadly, the Ciare tweeters are not available here in the US.
Great work!
Ciare is an Italian Brand, you could take a look on eBay, there is a Vendor who ships to US 😉
I found one Italian seller on ebay but he did not list the Ciare MT200 tweeter in his available products.
Thanks.
Thanks.
Oh, i think he has the other 2 versions:I found one Italian seller on ebay but he did not list the Ciare MT200 tweeter in his available products.
Thanks.
HT200 8 Ohm (identical to the MT200, without the magnetic shield) and the CT200 (4 Ohm version).
