Visaton AL170x2_DSM50FFL_MHT12
Maybe you can't, but someone else can..
I will try to attach here rew file.. wait for final xover version..
I don't mean anything bad, but the measurements were done amateurishly. You have instructions for correct measurement explained in great detail on the forum as well as in the program in which you measured. It's a shame not to use the full potential of the drivers.
Reactions: Zvu
My pleasure. Nothing can be seen from your measurements. Because they are smoothed not gated and the impact of the room on the measurements is great, how big we will see when you hang the measurement file from REW and see the impulse response. Again, there is an explanation of how to perform measurements correctly.
Reactions: Zvu
You dont read carefuly..
Swallows are back, garden measurements are impossible..
I have spring allergy too..
I read very carefully but I come across your avoidance of answers. Unless you are passionately following the swallows migration. I did not see any correct measurements in the previous project. So I suspected it had something to do with the migration of bird species. There is also the possibility of indoor measurements.
