What EL84 tubes do you like?
Possibly an honest mistake regarding the SV83.
Reminds me of the honest mistake of the Svetlana 6N1P data sheet.
They swapped the numbers of the transconductance, Gm, and the plate impedance, rp.
The usable area of the plate curves, at legal plate dissipation, shows a much more accurate Gm and rp, versus the
typographical errors for Gm and rp.
Do you have a schematic for this screen supply?
Here's a drawing from notebook, very simple, just make sure to use a N-channel enhancement mode MOSFET with gate protection diodes, I used a 2SK3563 because I had some. And use a carbon comp for gate stopper. Adjust zener string to suit voltage reqd , remembering that ~4volts less out due to VGS drop.
T6TC8RHOZrm_GCrUA1E9GFKP2uPiZuW9UhhwRvoBYA3WEQdG7XLBY1duDlejzDfvcELDlhoZ55iRl4m9-0evqSb3ZFJ-sVK_bKLOHQsanYOAjHbqTqypozark2Tb51OJvNdbIeCmhp35p55SU5jCv3XybrWozO6EcwmQnX-afyOndPrnVrHwNawcG5OaeKFWXeUxz3ZhFuConeO_vS8WrLmPx6_yJS9cWpKYghaA9Xek6p7eHaeosheOJYxHhtFJUY1uGl_41FjABhKJKb9lfcg52WHUVxeUZK0FCGHLS1iwFQXd0ibKcbXDfUZWKAgVNCjv_yJWIg_havreyNiJ3ESroU-RnTgsW87vFRBwO2fCii9cRxkDnMiR9-bTKINHcWx2Ex8lK2ZE3ipiyb9jelSWAcHZhCBGDB7pq5AvXKnXgvadCXxKZbS6eFbTCP-z8xeOgl3zXuG9TUSUYg-Un8ls1YuRkY0_Ykd-Eml1esHPfLH3--sgLExUBjJocWJ0LlX2p9V95uvwARYIE86IR-BhV1eLbX3Bu4J3c0ZXe-H2q-cEi4B5uzvEIvgKhLn9V4W1ufd-tN75PtXbO-n3IJf1518isdHbU60eqfjW9Onh15xtI7YlKUUgWE1W18OAmsERimTLzE93JtZHpYqPYboZdbT_jDFXWxkIZgLWXlW1VWW4gdpn_giX-VWqE2bikWnWsT-YhqYmgIyFZIE2ImZh2W0dlReaSreFDSNsM036CTcn27QQOKQdpXly=w1219-h1078-no
Very interesting! Am I understanding correctly the difference was positive - that you prefer the sound of your Tubelab SPP with “stabilized screen voltage” in Pentode connection over the Ultralinear connection?
Yes, I think it works better than UL in my amp, and it makes for very stable operating conditions for the tubes, noting that pentodes are "programmed" for plate current by screen voltage, and the self compensating nature of cathode bias. I used 330ohms per tube for Rk, for plate dissipation of ~10 watts using 330V plate supply and just under 300V on G2.
I don’t see a drawing. Forgot to attach it, perhaps?
Reactions: zdenoeddie
