The Speedsters that Too Bye Ate
Walked in a hardware store's lumber section, and while randomly walking past 12 foot kiln dried 2x8s of redwood, I saw the impossible ... the last 4 feet of one of those boards was burl. When I flipped it over, it was all the way through identical.
Thinking they may not sell it to me, I walked up to the lumber counter with it and the person told me I will just charge you for 8 ft , since that last four feet is all just trashy burl that can't be used. I only paid $22 for the entire board if I'm not mistaken. Took the four feet to a sawmill and had them slice it 3/32" thick slabs. Therefore there is a seam I tried NOT to hide. I wanted everybody to ask me why there's a visible seam down the sides, where I can tell them because it's made from a redwood 2 x 8 that could have ended up a floor joist!!!
Very nice cabinetry work, very nice finishing work. They look spectacular.
How much did the mill charge you to slice the board into veneers?
Thank you Jim. They charged me $40. The standard per hour cut fee. The guy was actually excited to do it, because he had never tried ripping a 2 by 8 that way LOL. He was as excited as to be when he called me to tell me how flattened perfect they came out
Reactions: kevinkr
Awesome Speedster build Flaxxer!! Good decision to go with the slot port, I can hear chuffing from the rear round port in mine. That 4” TB moves an incredible amount of air!!
:cheers:
If Flaxxer's slot port has the same cross-sectional area as your round port, that slot port will be more susceptible to chuffing because its perimeter dimensions are larger than the circumference of your round port. A round port has the smallest possible perimeter dimensions than any other shape port with the same area. If Flaxxer enlarged his slot port and also lengthened it to create the same tuning frequency as your round port, then it could have lower chuffing because it had a lower air velocity.
Paul
It is all compromise. The miniOnkens purposely have long hugh cross-section vents. Over many hundreds of builds no-one has complained of chuffing.
You need to do some extrapoation with a standard sim to ad din the affect of the added R in the vent.
I avoid round vents if i can.
dave
