Hey
I am looking for some EL84 tubes, or any other type that is compatible.
What tubes do you like and why?
I am not too fond of overly warm sounding tubes and neither with very bright treble.
Can you recommend something or just share your experiences?
Telefunken, Russian 6P14P-EV, Sylvanias Black Plates have peaked my interest so far.
Cheers
Cheers
You're getting close to pure conjecture in the response you expect when asking a question like this, but I'll say my favorites are the POLAM brand Polish made ones, very consistent in my experience and act as they should. Close second would be old Sylvania, followed by Russian surplus 6p14p and their EV version.
Well of course it's subjective. I've been using the Hungarian made Tungsram, I have to say when I changed from Electro Harmonix to Tungsram I only noticed very subtle differences.
6P14. Either Russian P, P-EV, or the plain Chinese one.
Of course RCA 6BQ5 are nice, but they aren't 4 times the price nice...
How do they differ from each other? I assume the Sylvania has a more fat and warm sound, but just a blind guessYou're getting close to pure conjecture in the response you expect when asking a question like this, but I'll say my favorites are the POLAM brand Polish made ones, very consistent in my experience and act as they should. Close second would be old Sylvania, followed by Russian surplus 6p14p and their EV version.
What's P,-P-EV?6P14. Either Russian P, P-EV, or the plain Chinese one.
6P14 - umbrella name for tube - Chinese versions usually don't have a suffix, but there is a 6P14-J I think which would be a rugged version.
6P14P Standard 6P14 from the Soviet Union.
6P14P-EV Rugged version from the Soviet Union.
Have you tried the -K version?6P14 - umbrella name for tube - Chinese versions usually don't have a suffix, but there is a 6P14-J I think which would be a rugged version.
I found one tube shop https://ussr-tubes.com/vacuum-tubes-type/pentodes and the 1970 version is -K 1980 is -EV, 1990 is -ER
this is confusing... originally it was written in cyrillic like this 6П14П-ЕВ we somehow translated the "-EB" to "-EV" no idea why, some still spell it "-EB". But I thought that 6П14П-ЕВ is the only Russian EL84/6BQ5 military version.
Idk how people come up with "-K" and "-ER"
I haven't found much subjective difference in good tubes that are well matched, comparing plain 6P14P (Russia 70s-90s) to Philips (Amperex in US) Holland, not much in it. Also tried some vintage Mullard and Tele, not enough difference to make it worth burning up vintage tubes.
Amp is a lightly tweaked Tubelab SPP with 7600ohm 25watt Hammond O/P iron (1650FA).
Disconnecting the UL taps and using MOSFET and zener string for stabilised screen supply made much more difference than tube rolling IMHO.
the "K" version does exist, and is supposedly for high vibration, very uncommon to find it seems, I have one single one that came in a bulk lot of other 6p14p that I picked up on ebay a couple years ago from a seller in Ukraine. I'm not very good at remembering how the letters transcribe over to eachother.I found one tube shop https://ussr-tubes.com/vacuum-tubes-type/pentodes and the 1970 version is -K 1980 is -EV, 1990 is -ER
They sound about the same to be honest, but I found them more consistent than the Sovtek and basic 6p14p surplus. Easier to find a set that bias up closely to eachother in situations that needed close idle current for a given bias voltage.How do they differ from each other? I assume the Sylvania has a more fat and warm sound, but just a blind guess
You want a rugged tube?
Try the 7189A's NOS.
Pay the price, but they last forever.
I've got a quad of them by Realistic "Lifetime" Gold in my one amp and they're excellent.
Do you have a schematic for this screen supply?I haven't found much subjective difference in good tubes that are well matched, comparing plain 6P14P (Russia 70s-90s) to Philips (Amperex in US) Holland, not much in it. Also tried some vintage Mullard and Tele, not enough difference to make it worth burning up vintage tubes.
Wait how does it exist and not exist at the same time?the "K" version does exist, and is supposedly for high vibration, very uncommon to find it seems,
What is the amplifier that these EL84 tubes will go into?
I suspect possible differences in the sound of various manufacturer's EL84 tubes, versus:
Guitar Amplifiers
Hi Fi Amplifiers
Single Ended with:
Pentode mode, UL mode (and UL tap %), Triode mode
Push Pull with:
Amplifier topology, local negative feedback, global negative feedback, output transformer, etc.
1. Plate voltage and plate current.
2. Screen voltage
3. Cathode current
Grid Bias Voltage necessary to get 1, 2, and 3 as desired.
Some EL84 tube "substitutes" (SV83 for example) may have major problems in many amplifiers (Maximum allowable screen voltage).
Negative feedback can "hide" some sound characteristics, and "bring out" other sound characteristics.
No negative feedback can "hide" some sound characteristics, and "bring out" other sound characteristics.
Context please.
Just needs to be tested as they will be used.
If you do not have UL taps, then UL operation is out unless you want to add lots of circuitry. Such a shame, UL with OPTs that have UL taps is easy, not easy without any UL taps.
Just my opinions.
Guitar Amplifiers
Hi Fi Amplifiers
Single Ended with:
Push Pull with:
2. Screen voltage
3. Cathode current
Context please.
Just my opinions.
Very interesting! Am I understanding correctly the difference was positive - that you prefer the sound of your Tubelab SPP with “stabilized screen voltage” in Pentode connection over the Ultralinear connection?I haven't found much subjective difference in good tubes that are well matched, comparing plain 6P14P (Russia 70s-90s) to Philips (Amperex in US) Holland, not much in it. Also tried some vintage Mullard and Tele, not enough difference to make it worth burning up vintage tubes.
As Linwendil said. It definitely exists - I have some in my stash, but have not used any, so I have no opinion on sound. According to Vivatubes, that has some for sale, it is “the most musical version of 6P14P”. https://www.vivatubes.com/true-nos-soviet-russia-6p14p-k-el84-6bq5-vacuum-tube/Wait how does it exist and not exist at the same time?
IIRC the specsheet gives it a 1000 hr life.
In these times of scarcity of good 6P14Ps I believe these under-appreciated “substitutes“ deserve another good look.The datasheet for 6P15P below, clearly shows a ug2 max of 330V, but with 1,5 vs 2 watt dissipation (for the EL84). Suddenly, when Svetlana started their US sales operation they relabled the same tube as SV83 with a datasheet that is wrong regarding ug2. I don’t know if this was an honest mistake, or a deliberate sales decision.
- Tubes / Valves
- What EL84 tubes do you like?
