Not easy to part with but if someone needs it it better get a good sue than just sit and wait for me to retire.
1.Mark Levinson 36s DAC boards, 3pcs. 300euro
2.Mark Levinson CD39 DAC board 200euro
3. Linn Axis outer and inner platter, bearing and motor, perfect for DIY turntable 225euro
4.Tag McLaren 10x5r modules, NOS from a repair shop 125euro each, 7pcs. 750euro for all.
5.Arcam P7 modules, 2pcs. plus one with a switch missing for spares. 150euro for all three
6.Mutec 3+USB with some marks on the case but has a professionally fitted input for a PSU on the side. Fully functioning, easy to listen improvement on all digital sources. 650euro.
7.Wadia 921 DAC board, single but has 4 pcs. of selected PCM1704 Ks on it and someone can make a good DAC of it. 200euro
8.Mark Levinson 38s preamp board that was checked working and has 380s firmware installed. Comes with the difficult to find OLEDs for the display and a front plate of the original remote. 650euro.
For paypal please add 4%, shipping in EU will not be much.
Would be happy to answer questions.
I don't know much other than they came from the stock of a repair shop and were never used. I have seven, pretty heavy.
Each power amplifier module contains its own mains transformer, bridge rectifier and energy storage capacitors, on forums(fora) people say that changing the caps makes them an entirely new beast with top level sound, basically each channel is a monoblock. It uses top quality parts, I saw 2SK389s inside and good transistors with custom heatsink, transfomers are custom Noratel as well, it was part of the effort to establish Tag McLaren as a very high quality audio brand. I think it can be bridged as well for higher power. Probably needs a soft start and the caps of the binding posts are missing.
Here are the specs I found:
Specifications rated output power 100 W into rated load impedance (8 Ohms) typical output power 120 W per channel into 8 Ohms, 160 W into 4 Ohms and 190 W into 2 Ohms for short periods input for full rated power 1.0 V rms input impedance 47 kOhm nominal gain 29.0 dB at 1 kHz signal to noise greater than 90 dB (relative to 0 dbW) frequency response ± 0.05 dB from (-3 dB) 20Hz to 20kHz; -3dB @ 0.2 Hz and 87 kHz total harmonic distortion + noise less than 0.002% @ 1 kHz 100 W into 8 Ohms, less than 0.05% from 20 Hz to 20 kHz @ 100 W into 8 Ohms polarity non-inverting between any input and output operating temperature range 10 - 35°C ac supply frequency 50 - 60 Hz ac supply voltage 100 V, 110 - 120 V or 220 - 240 V
Tagmclaren
These modules are top but have the problem of a microprocessor driving all functions including speaker protection .
Indeed the Tag modules are very good, I had a friend who had a look at them and it is not so bad, especially if you do not need the speaker protection. They are a good deal for someone who needs great amps for a 3 way active or a home cinema set and knows how to use them, a lot of very smart engineering went into them.
For a two channel amp the Arcam P7 modules are fantastic if you already have a transformer.
Lots of PMs but no one followed with interest...
The Wadia 921 board just sold, the rest is still for sale. The list will be updated shortly with new stuff. Thanks to all the people who asked!
Mark Levinson DAC boards are going to a good home, Mark Levinson preamp board will be off sale and going for a personal use 🙂
Left for sale are:
Mutec was stolen from a DPD office by an employee 🙁 If someone sees a black one with a connector on the right side for an external PSU please let me know 🙁
Left for sale are:
Which are those chinch connectors and can you post some more info on them? Thanks a lot!I found some RCA and XLR connectors for the ML 38s board that I will include. View attachment 1038552
Those are the ones that come with the Mark Levinson 38s preamp board but I finally found someone who can help me with the display board and plan to use it so the board and the connectors are no longer for sale… Thanks for checking the ad.
Yes, I know but do you have a source for them or manufacturer name, model, etc?Those are the ones that come with the Mark Levinson 38s preamp board
Like I know about those Neutriks, but not about the chinches. Thanks for any hint.
Hi, Arcam P7 modules are still valid ?
If yes, I'm interested
My email is: jasminka1981@tlen.pl
I have a guy who asked some time ago, having difficulties locating their box in the storage 🙁 I have so much stuff that I feel like a criminal, especially when people need it and I can’t find it 🙁 But I am working on it…
