People have used replacements but the CCS may have to be adjusted to get the 'biasing' right. The following may work but I've never tried it.
https://www.mouser.com/datasheet/2/308/1/FQP34N20_D-2313710.pdf
Other possibles:
https://www.mouser.com/c/semiconduc...Package / Case|~Id - Continuous Drain Current
Other possibles:
I have 38
Other possibles:
https://www.mouser.com/c/semiconductors/discrete-semiconductors/transistors/mosfet/?id - continuous drain current=31 A~~50 A&mounting style=Through Hole&number of channels=1 Channel&package / case=TO-220-3|~TO-220AB-3|~TO-220F-3~~TO-220FL-3&transistor polarity=N-Channel&vds - drain-source breakdown voltage=200 V&instock=y&active=y&sort=id - continuous drain current&rp=semiconductors/discrete-semiconductors/transistors/mosfet|~Package / Case|~Id - Continuous Drain Current
I have 38N20. How do I know if to adjust css or not.People have used replacements but the CCS may have to be adjusted to get the 'biasing' right. The following may work but I've never tried it.
Other possibles:
If there is no distortion, they may be a drop-in replacement.
Did you replace the low-side NPN driver transistors that commonly fail in these amps?
