Volume control options for tube preamp
Can we run through the common options for volume control on a tube preamp giving pros and cons?
Examples:
  • log volume control
  • fake log using linear taper with a resistor, and best resistor values
  • stepped attenuators of different constructions including shunt types
  • TVC and autoformer
  • other types
What are you using, how did you make that choice, and how do you like it?
Others will give info like the Zout of a pot at centre vs near the edges etc.
I can tell you I've used cheap pots, RK27 Alpha pots, and stepped attenuater that was Ladder type using 8 relays.
There were not enough steps for me, and I prefer the RK27. The cheap pots are ok, but the lowest part of the volume setting ramp up faster t han RK27, and usually the left and right tapers aren't aligned which means the left channel will make sound before the right at the lowest settings. The 10 o'clocl setting on the RK27 is like 8 o'clock on the cheap one (Bournes).
You can get RK27 for 25$ from Mouser, but 8$ from GD Parts or LCSC...
If I knew more about how to control modern microcircuitry, I'd design one using PGA2310.
EDIT: Maybe I don't have to know... https://www.audiophonics.fr/en/prea...dule-pga2310-with-rotary-encoder-p-13416.html
Reactions: stenak and Jcris
We use a stepped attenuator with 6 relays arranged in a binary fashion, 6 attenuators with 1, 2, 4, 8, 16 and 32dB attenuation, this gives 1 dB resolution with 64 steps. Much better channel balance than any pot.
Do you know that ALPS only promise 3dB balance for the RK27 or even as much as 5dB at low settings?, with standard 1% resistors in a stepped attenuator you easily get better than 0.2dB balance
IMHO:
  • TVC (only if you have low impedance source). BTW I don't listen SQ waves. 🙂 ;
  • AVC (only if you have low impedance source);
  • Plastic conductor potentiometers ( Noble, TKD 25xx, ALPS RK40 Black Beauty etc.);
  • Good stepping attenuators (for example shunt types);
  • Ladder stepping attenuators;
  • Series stepping attenuators;
  • Simple potentiometers (like ALPS Blue).
Motto: all roads lead to Rome.
p.s. I used TVC, AVC, Noble, TKD, RK40, stepped attenuator, and many potentiometers.
They might, but I've never used one that was perceivably off. They are much better than any bog standard one you'll find at Digi-key anyway 🙂
The problem with a stepped attenuator is the steps. 64 steps of 1db? No thanks. 1024 steps at 0.1db? Maybe.
The biggest problem with potentiometers is not static unbalance between channels but rather that unbalance can change with volume setting, e.g. at low volume there is unbalance to one side and then it changes to the other when increasing volume. I have tested RK27, RK40, Noble and TKD CP2500 and none of them is very good. They all suffer from the same problem, and it is understandable as the specified performance is not very good.
Similar.
http://www.intactaudio.com/atten.html
IMHO:
I've been looking for a simple good quality stereo 100K log taper, or even linear which I could make into a fake log taper, for sale in the UK. Very poor choice. I couldn't find any of the conductive plastic ones you mention. The Alps Blue is available but I was expecting more choice than that. Maybe I'll have to look at European suppliers. Any suggestions?
TKD is conductive plastic.
I usually use CP-2511.
https://www.hificollective.co.uk/catalog/tkd-potentiometers.html
