100W Ultimate Fidelity Amplifier
  • a;pex FX-12 BTM CU.pdf
  • apex FX-12 TOP SILK.pdf
  • FX12_2022-03-04.zip
    FX12_2022-03-04.zip
here you go..🙂
Apex Shunt psu from post#13477.
I’m getting an output 2v lower than the installed zener diodes.
ZD24 = +/-22vdc output
ZD15 = +/-13vdc output
ZD12 = +/-10vdc output
All examples use appropriate transformer CT secondary voltages: 24v, 15v, and 12v.
Dummy load = 100mA
Is there an adjustment to the resistor values needed to get the correct output voltage?
AA9MD - do the output devices need to be matched?
I have AA9MD running for short periods until rail fuse(s) blows. I can listen to the amp but at around one minute the fuse blows.. same when testing the amp with 1khz sine or square wave , everything looks good for about one minute, then rail fuse blows.. Guessing, but appears to be thermal Runaway.. Any suggestions would be helpful, thanks.. I have feedback jumper installed..
