For Sale Bits and Bobs
Things you have for sale.
Hi All,
A few bits for sale:
1) Furutech FI-1363 UK plug
"This item is made to exacting standards and fully CE approved, audiophile grade.
Featuring copper contact pins and cryo treated and de-magnetized using Furutech''s patented Alpha process which removes internal stresses from within the material and helps to improve conductivity as a result.
The plug can accept a wide variety of cables of varying diameters up to 15mm and beyond. The plug is perfect for DIY as it has a patented cable clamping system which is very easy to adjust"
Used for around 3-5 hours, then taken off to repurpose the cable it was on.
As good as new, £50 delivered UK
https://uploads.tapatalk-cdn.com/20220314/59f2a49cb6f160829f6f2e396a95f4b3.jpg
https://uploads.tapatalk-cdn.com/20220314/308bd242cc93073168d6adad8e9ef625.jpg
https://uploads.tapatalk-cdn.com/20220314/7165f18547d27f8614815e16986780e3.jpg
2) 20K TKD 2CP-2511 Dual, Stereo Potentiometer.
"The TKD (Ko-on) potentiometer is highly regarded, probably one of the best pots in current manufacture, as used by Audio Note. Please note this is not your standard taper potentiometer but is a shunt attenuator/taper type to give you better performance than your standard taper potentiometer."
This pot is a massive step up from the Alps Blue that seems to populate so much gear. Genuinely resolving, Excellent accuracy of tone and has a really honest sound. I was genuinely impressed with it in the Prototype BT2. No longer required, solder once and now removed. Used for 8-10 hours max.
This cost me around £100, so £75 delivered UK seems fair.
https://uploads.tapatalk-cdn.com/20220314/323d6f2950f95770c651dac9122fbf0b.jpg
fyi
That´s from acoustic-dimension
