Here are a couple from Dave's library: http://www.frugal-phile.com/boxlib/P10free/CGR-dCHR-Ken-301113.pdf
jeff
jeff
I think I’ll try the double (hyper) bass reflex design, I’m thinking that I will construct out of solid 19mm spotted gum hardwood which is very dense (950kg/m3)
Any thoughts?
Any thoughts?
When using 19 mm, adjust the size of the parts so that the inside volume does not decrease.
If you use hard solid wood, the sound will be harder, so increase the sound absorbing material as you like.
Thanks for the feedback, will do.When using 19 mm, adjust the size of the parts so that the inside volume does not decrease.
Steve
- Full Range
- Looking for cabinet ideas for Mark Audio drivers
