3-way Kharma clone
After selling my beloved Martin Logan Sequel II I'm playing with the idea to build a set of loudspeakers with the Veyron 4D design as a starting point:
Not sure about the drivers.
First idea for the drivers:
1x SBA Satori TW29BNWG
1x SBA Satori MW19P
2x 11" Woofer ?
What would be a good choice of drivers? I would like to try a berylium tweeter but also read some good stuff about those Textreme woofer/tweeters.
2400 euros for the woofers alone. That's just crazy. Don't do it.
Troels' Revelator 851 is a nice starting point. D3004/660000 (own these!), 15M/8631G00 and two 22W-8851T00 per side. The money you save on the woofers will buy you two Hypex FA253 modules(own these too!). You'll never look back.
If you have over 100 L volume why not use 2 scans 26w8867 a lot of ppl have reported excellent performance in 50 L per woofer enclosure. And Kharma has used it in their Exquisite line(probably custom versions) but you know it’s a good woofer if they use it. Also Wilson audio used it. I ll be using same basic kharma look for my next design but it will be all scan speak with double 8s. Good luck
