Newby question about parafeed OPT
The parafeed topology couples the OPT using a capacitor. Doesn't this then mean that the primary impedance of the OPT is pretty much a moot point? As long as the capacitor is sized properly for LF cutoff does the output tube really care any more what load it is working into?
For example lets say I had a 45 tube and I had three OPT's, one has a 10K primary another has a 7K primary and the last one has a 5K primary. If it was not parafeed then the 5K would be the best choice for the tube to work into and the 10K and 7K the poor choice. With parafeed is that still true?
If the cap is sized properly, it can be considered almost a dead short for all relevant audio frequencies ... otherwise they wouldn't pass unaltered.
In other words: the cap is open circuit for DC but nearly like a piece of wire for AC.
Windcrest77,
Now you have been given 2 very good explanations.
Just use the same primary impedance for the Parafeed output transformer, as you would use for a non-parafeed output transformer (OPT).
Parafeed OPT uses interleaved laminations, such as interleaved Es and Is. No air gap required, since there is no DC current in the primary.
Non-Parafeed OPT uses alternate stacked laminations, such as E then I then E then I . . . They require an air gap, since there is DC current in the primary. All the Es on one side of the air gap, and all the Is on the other side of the air gap.
A 'C core' single ended OPT is similar, there are air gaps between the two 1/2s of the laminations, to allow for the DC current.
The parafeed circuit low frequency phase and low frequency response depend on several things:
Plate choke
Parafeed coupling cap
Inductance of the parafeed output transformer primary (normally high in a parafeed OPT).
And . . .
The Reflected load of the loudspeaker's various low frequency impedances versus frequency (these reflected load impedances are in parallel with the normally high inductance of the parafeed OPT primary).
Example, an 8 Ohm load on a 5k to 8 Ohm OPT reflects 5k to the primary; and a 4 Ohm load on the same 5k to 8 Ohm OPT reflects 2.5k on the primary.
Many 8 Ohm rated loudspeakers can have minimum impedances of 6 Ohms or even 4 Ohms at some bass frequencies.
I see, so using a gapped OPT is kind of a waste if you're doing parafeed, may as well save that OPT for a different conventional SE project? Not having to create the air gap you can get a transformer with more exotic materials, more inductance, etc. right? So who makes "parafeed OPT's" these days? Or do you just order a transformer from Jack Elliano with no gap? I see why parafeed is popular with headphone amps, you can use line level output transformers, for that matter even line level input transformers as long as the secondary matches the phones and you're reflecting the right tube load. Lundahl should have something too.
