The microphone need 48V 70mA(but I want to use minimum 2), sensitivity -48dB, self noise 5dB. So I think I need smaller than -137dB noise from power supply. 94-5=89; -48-89=-137
Phantom is limited to 10mA per microphone.
In Phantom the power is common-mode, the signal is differential, giving a LOT of power supply noise rejection.
Why not try the $49 phantom supplies from the guitar store?
The mic need 70mA @48V phantom.Phantom is limited to 10mA per microphone.
Phantom power as PRR points out is limited by specification to 10 mA.
Phantom power is sourced from 48V by two 6.81K resistors that can only source 7 mA each into a dead short. 14 mA total.
If your microphone, which you do not specify, requires 48V at 70 mA then it is not Phantom-powered.
It is 48V-powered but not Phantom-powered.
Since you're not willing to tell the people who are offering to help you information they could use to research it further you're probably going to be on your own.
I quoted the manufacturer. It is no accident that I have enclosed the sentence in quotation marks.
The product page, manual and datasheet do not give a current requirement specification.
Here are some links you could have provided from the beginning.
https://www.esi-audio.com/products/cosmik10/
https://download.esi-audiotechnik.com/download/ESI/cosMik_10/cosMik_10-English.pdf
They read:
Maybe the person you quoted from the email was wrong or there was a typo.
They read:
- requires +48V phantom power
- Power Supplies
- <-137dB Low noise phantom power for microphone from USB
