Control SigmaDSP ADAU1701 / ADAU1401 from PC
I think there are two kinds of "support":
1. If you want to manipulate the parameters thus control the behavior of DSP, not much in my package needs to be modified to support ADAU1452/1463/1467, since algorithms they implement are largely the same. You just call up a "Cell" object which represents a SigmaStudio Toolbox algorithm and use it to manipulate related parameters.
2. However, if you want to have total control of hardware chip, since ADAU1452/1463/1467 are ways more complex than ADAU1701, a lot a lot more code has to be implemented to have full coverage of their functionalities. I won't try to do that.
2.1 In my package, "ADAU" object just control the I2C bus, thus can be used to read/write parameters, even you don't know the details of hardware chip. The sub-class "ADAU1701" however implements every details of the hardware chip.
2.2 Thus, you can still manipulate parameters with "ADAU", without the detailed sub-class ADAU1452/1463/1467.
I think the first kind of support is not difficult, but I'm not sure since I have no ADAU1452/1463/1467 thus unable to test it.
